My Bonneville Project up date
#483
Corey Say send Him one as soon as you can, we have to get the cars in the trailer and begin packing in 30-40 days.
This would be fantastic, we're running 8200-8500 rpm and the OEM runs in batch fire above 4400 rpm. And the thought of seeing data on the top end would be just the ticket. The density altitude is about 5500' in August.
please proceed with Corey Let me know what you can do.
Dave.
Oh I said Cars, yes R & D Landspeed Racing ( Rick and Dave) are taking two cars to the salt, for our Racing to Heal Fundraiser.
more data , and a picture of the other car to follow but for right now lets just say its a C4 and its wicked fast.
Oh and I would like to thank Jerrys Gaskets for their support in our efforts.
Dave.
#485
The valve opening time above that makes sequential fuel useless. It eats processor time and gains nothing in the end. Go with the batch and use the extra processor time for on the fly fuel flow tied to wideband units on each side. Fastlane used a wideband on each cyl when he was racing his car and a Motec computer, Also used a Jerico.
Tyler
#486
Tyler
Tyler
#490
love to hear more about the megasquirt this is the perfect application and the WOT data logging and tuning is amazing
I'm interested in installing the megasquirt to control only the secondary injectors and also going to a coil on plug
I'll have to give corey and ron a call. the plug and play setup they have developed is amazing.
#493
This is from an earlier run with wet salt, after a rain. 229 mph. I rolled on to the throttle and short shifted 1 and second as traction was limited. if you watch the mountain at the edge of the window you will see how much the car moves around at the 3 mile. Change the setting to 720HD and you can read the GPS
#494
GOPR0022 - YouTube
GOPR0022 - YouTube
#495
its like driving on hard packed snow, but reaction times are too slow at those speeds if you to do much more than nudge it back toward the track, your going to spin as you will most likely set up the C4 shuffle, you know it , first one way then the next and then round and round you go :-)
#497
I am wondering how the Mega Squirt system worked as Corey is working on getting it installed in my 90 twin turbo Raptor project. I'm hoping it worked well for you.
Ron Bidwell
Ron Bidwell
#499
Ron , we did not run the Mega Squirt, just Did not have the time to work it out before the runs.
I hope to try it with next years build, where we hope to equate $ in to HP.
#500
Ok its next year, and the motors about to go back on the dyno, with new profiled cams to make power up to 9500 rpm, ( we flattened off between 8000-8500 on the stock cams) also a bump in compression to over 15:1
Wish us luck and come see us at speedweek 2015 as the ZR1 is about to be King of the salt. all we need is 1/2 mile per hour improvement from last year to set a new record.
Dave
