C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
(fs) 1991 zr1
Old 11-07-2010, 01:10 AM
blkzr1
blkzr1's Avatar
Default (fs) 1991 zr1
I hate to, but i have to part with my black/black 1991 ZR1. $21,000
The bad first:
1. The pass. seat forward and rearward works fine except when you get the seat all the way back, then you have to "help" the seat forward again about an inch, then it works fine again.
2. There is a small scratch on the front bumper where the previous owner may have bumped a parking lot pole or something. The scratch has been touched up.
4. The CD player will not pull a CD into the player.
5. There is a small cut/scrape on the drivers side lower seat but the cut/scrape does not go through the leather. It is just a surface mark. It can be seen in the drivers seat picture.
6. There are small droplett stains on the outside of the lower plastic pannel where some battery acid got on the paint.
7. The engine paint is stained but not badly.
8. The paint is a 9 to 9 1/2 on the car.
9. Slight windshield delamination on original windshield. No rock chips.
10. There are small water droplett stains on the gray center console.
11. The stickers on the wheels are gone.
12. There are some small rock marks on the lower rocker pannels but not chips that go through the paint.
13. There is a very small spider web type paint blemish on the right side of the hood as seen in the picture. The blemish is just above the coolant holding tank.
The Good
1. The car has 21000 original miles on it. I bought it with 3,400 miles on it.
2. I replaced the old injectors with FIC rebuilt injectors, bosch II, less than 1000 miles ago. The originals will go with the car.
3. Checked all things under the plenum and all plastic hoses in good condition and flexable. All vacuum valves work as designed. Cleaned out mouse nest and pulled starter and all is ok. No wiring is chewed up by said mouse. Pulled vacuum on secondary system with a vacuume pump and it held perfectly.
4. Replaced spark plug wires with the red GM wires.
5. Both tops are with the car.
6. Bose receiver under the dash has been rebuilt by Dr. Dons.
7. Tires are in very good condition. Nitto 555 less than 1000 miles.
8. Front A arm bushings are replaced with poly bushings.
9. Pizza box is all there and comes with car. Also, original window sticker is in the box.
11. Compression test was run when new plugs were put in and the test results showed 210 psig +/- 3 psig.
12. Shocks are not leaking.
13. Engine has been dyno tuned by Corey Henderson at Henderson Performance Technologys. The results were 348 hp at rear wheels and 352 tq. on all original car. I have the dyno sheets to go with the car.
14. Corey had installed a coil over suspension but i have put the suspension back to stock.
15. Antifreeze has been completly flushed and replaced with green.
16. Brake fluid has been completly flushed through the calipers.
17. Everything is original except plug wires, fluids, plugs and front a-arm bushings.
18. Car has been lowered about an inch.
19. Interior is a 9 1/2 only because of the small cut on drivers seat and stains on the console.
20. I never retreived the build sheet but it can be seen folded up in the k-member.
21. I am the second owner outside of the dealership that owned it from the original owner to me. I was able to speak with the original owner before i bought the car.
23. The transmission fluid has been changed 2 times with the BMW M-5 oil.
24. The engine oil has been changed 6 times. I used Mobil 1 10w30. AC, oil and air filters also changed.
25. Oil has just been changed at 20360 miles. Bosch filter used and oil cooler oil changed also.
I have many pictures that I can e-mail or text to anyone. The car can be seen on Amarillo Craigslist under 1991 ZR1. There is a price difference you will see because forum members should get a better deal.
My asking price to forum members is $21,000.
Thanks for looking.
The picture in the avatar is the car after Corey lowered it at about 10,000 miles.
Old 10-17-2011, 04:32 PM
-=Jeff=-
-=Jeff=-'s Avatar
Originally Posted by blkzr1
hi, the zr1 is back up for sale again. can someone help me with posting pics? ttt
Sure send them to me.. vettxtc@gmail.com
I will post them tonight
Old 10-23-2011, 10:29 PM
-=Jeff=-
-=Jeff=-'s Avatar
https://picasaweb.google.com/1013380...992078/1991ZR1
Old 10-24-2011, 07:16 AM
HammerZR1
HammerZR1's Avatar
What's the VIN or the car number (last 4 of VIN).
Nice looking, good luck w/ the sale.
Old 10-24-2011, 11:30 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Seller is a stand up A-1 guy, buyer will have no issues doing a deal or surprises.
Old 10-24-2011, 05:59 PM
blkzr1
blkzr1's Avatar
Default zr1
hi, the last four of the vin are 1545. thanks
Old 10-24-2011, 09:27 PM
HammerZR1
HammerZR1's Avatar
Thanks for the car number. I just noticed the original thread was posted almost a year ago. Did you try to sell it and then decided not to, and now you want to sell it?
Old 10-24-2011, 10:08 PM
LowFlight
LowFlight's Avatar
St. Jude Donor '03, '17
Senior Member
Cruise-In V Veteran
Nice....
Old 10-26-2011, 08:41 AM
-=Jeff=-
-=Jeff=-'s Avatar
hi, yes, it was for sale about a year ago because i thought i was going to move. now i am going to move for sure. a big THANK YOU to -= Jeff =- for posting pictures for me. i have more pics available for anyone interested.
No problem, you can always send me more and I will add them to that album
Old 03-30-2014, 02:28 AM
blkzr1
blkzr1's Avatar
Default 1991 zr1 for sale
hi, my zr1 is up for sale again due to job situations. i can send as many pics as needed. thank you
Old 03-30-2014, 03:21 AM
blkzr1
blkzr1's Avatar
Default 91 zr1 for sale
well, the pics are on the new photobucket but i dont know how to get them here. i will send pics to anyone who wants to see them via e-mail. see ya
Old 03-30-2014, 02:58 PM
ZR-71
ZR-71's Avatar
St. Jude Donor '15
Just go to your photobucket library and click one at a time each pic you want to post and copy the website link, then paste it into your new post, or original post. The copy/paste is done one pic at a time.
Old 03-30-2014, 11:40 PM
Z51JEFF
Z51JEFF's Avatar
Ive got to agree.Years ago when I was looking to lower my car Mike gave me some helpful info.
Old 10-02-2016, 05:41 AM
blkzr1
blkzr1's Avatar
Default 1991 ZR1 for sale
To the top again.
Old 10-03-2016, 11:50 PM
cv67
cv67's Avatar
St. Jude Donor '05
Jeez Mike I hope everythings ok with you give a call sometime/pm
This is more than a standup guy gents
To (fs) 1991 zr1
Quick Reply: (fs) 1991 zr1
