C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
C6 Z06 brake upgrade
Old 06-28-2013, 03:26 AM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
Originally Posted by 95ZR1
This is the set-up I have on my Z. The 18" CTS donut spare fits
and clears a C6 Z06 caliper WITH AN ADAPTER/SPACER
Ted's was done "correctly" with an adapter that is hub centric to the car and the 12mm hardware and also hub centric with 14mm hardware to the CTS wheel. There were no "short-cuts"! There's no grinding on the wheel center bore to fit, the CTS spare retains it's complete resale value if it were ever an option.
Would it have gone better had I been in the "neighborhood"? Maybe!
Old 06-28-2013, 10:18 AM
93Polo
93Polo's Avatar
CI 3-4-5-9 Veteran
David, car looks awesome
I haven't done the rears because I want to keep the parking brake,
and I don't want to have to buy/install different backing plates.
What is your plan?
Quick google search looks like you can possibly keep the parking brake:
http://forums.corvetteforum.com/c4-t...onversion.html
Old 06-28-2013, 11:44 AM
LT4POWR
LT4POWR's Avatar
It also depends on what brand/style of 18inch wheels too... Sadly CCW told me that their 18inch wheels (at least the classics that I have) won't allow for C6 ZO6 brakes
Old 06-28-2013, 01:37 PM
USAFPILOT
USAFPILOT's Avatar
i think I heard my Shelby 18"s wont work either...need confirmation.
Old 06-28-2013, 02:31 PM
5abivt
5abivt's Avatar
How big are the c6z rotors?
If anyone knows who makes brackets front and rear plz post or pm!
Old 06-28-2013, 02:46 PM
LT5corsa
1994 Admiral Blue ZZZZZR1
Support Corvetteforum!
LT5corsa's Avatar
Northeast Events Coordinator
Definety won't fit Shelby's, sorry
David
Old 06-28-2013, 02:47 PM
LT5corsa
LT5corsa's Avatar
PM me our email address and I will forward you a link
David
Old 06-28-2013, 04:59 PM
Dominic Sorresso
Dominic Sorresso's Avatar
C6Z rotors are 14".
Old 07-03-2013, 08:51 PM
UR LZN
UR LZN's Avatar
Some notes I collected:
Rotor Diameters/Thicknesses:
C5
Base: F 325mm/R 305mm. 12.6/11.8 inches (from my spces)
C6:
Base: F 325mm/R 305mm. 12.8/12.0 inches
Z51: F 340mm/R 330mm. 13.4/13.0
Z06: F 355mm/R 340mm. 13.9/13.4
ZR1: R 394mm/R 380mm. 15.5/14.9
All (3) variants Rotor thickness (with exception of ZR1): F 32mm/R 26mm
2013 Grand Sport
Other highlights include 18- and 19-inch wheels, a Z06-style splitter and spoiler, functional brake ducts, and Z06-size brakes, including 14-inch front rotors with six-piston calipers and 13.4-inch rear rotors with four-piston calipers.
2010 Grand Sport (formerly Z51)
The Grand Sport replaces the previous 'Z51' which was equipped with the following enhancements;
Z06 brakes, including cross-drilled 355 mm (14.0 in) front rotors and 340 mm (13 in) rear rotors
Old 07-03-2013, 09:23 PM
-=Jeff=-
-=Jeff=-'s Avatar
David
Not True.. ShayneZR-1 did that to his..
BUT it is a bunch of machine work to the Shelby's and the C6 Caliper.. but I have seen pictures of them on there together
Old 07-04-2013, 12:33 PM
5abivt
5abivt's Avatar
I'm looking into the c6 zr1 brakes. Since they can bolt on the c6 surely they can fit with new brackets. I picked up c6z calipers but I may end up using the setup on the 93 since it could use the better braking f/r with 2 piece rotors etc. or I may just sell the new Baer kit and the eradispeed 2 pc rotors I already have and put the c6z setup on the z and do a c6 zr1 setup on the 93. Fun fun !
Anyone interested in the Baer 6 piston front calipers brand new w/brackets and lines and pads ? All new. I could include Baer 2 Pc rotors front and back too since ill likely not be using them.
Old 07-04-2013, 01:30 PM
Dominic Sorresso
The C6 ZR brakes are 15" so you'll need 19" wheels. And since the rotors are carbon ceramic, it won't be inexpensive either.
Old 07-05-2013, 01:23 PM
  #33
5abivt
5abivt's Avatar
I'm running 19s on both cars but yeah I didn't consider the cost of the ceramic rotors .. Big $$$ I think !!
What brake lines are you running with the c6z calipers? Will the c6z lines work or custom lines ??
So far I got the calipers ordered. Front brackets. Waiting to order the rear ebrake setup. Will likely get new rotors and pads but to keep costs down for now I might use the Oem padlets and source some used rotors. Didn't want to buy new rotors when ill be wanting to buy a decent 2 piece rotor soon enough. Been told I need a universal ebrake cable to for the factory ebrake to the new rear ebrake... Cost piles up really fast wow !!
Old 07-05-2013, 01:44 PM
  #34
Dominic Sorresso
I used C6Z SS lines for the fronts. Fit fine.
Old 07-05-2013, 01:48 PM
  #35
5abivt
5abivt's Avatar
Awesome thanks. Ill just reuse the ones on the calipers for now to get rolling as well as pads. Looking for rotors .. Seems a few options around $300 for all 4 with directional vanes isn't bad. Will try and source some used for now though. Street shoppe brackets are $700 ouchy .. But to have a working ebrake is nice. Wish someone would just make a rear bracket for $100 so I can snip the ebrake. Then again that one day the car rolls and park itself into another car or wall and ill be kicking myself lol
Old 07-06-2013, 05:09 PM
  #36
Dominic Sorresso
Is this a CTS spare or a CTS-V spare?
Old 07-06-2013, 07:53 PM
  #37
LT5corsa
LT5corsa's Avatar
Are you talking C6 caliper or C6 Z06? They will need heavy modifications to work the front and impossible to do the rear.
Regardless, I was saying unmodified Shelby's won't fit.
David
To C6 Z06 brake upgrade
Old 07-06-2013, 08:59 PM
  #38
-=Jeff=-
-=Jeff=-'s Avatar
David
C6Z06 and yes, mods need to be done to the Shelby Wheels.. Not really worth the effort IMHO but it can be done and you are right they cannot be fitted without the mods
Old 07-06-2013, 09:22 PM
  #39
combatdoc
combatdoc's Avatar
would it help if I had my buddy bring his c6 Zo6 over and I test fit a shelby wheel on it? Maybe get an Idea how much space is needed.
Old 07-06-2013, 09:47 PM
  #40
locobob
locobob's Avatar
I did this test fit and yes a lot of work is needed.
Quick Reply: C6 Z06 brake upgrade
