No Start after VATS bypass...
My '91 ZR1 still starts every now and then even after I installed a Mid America VATS bypass. I would appreciate any suggestions on what could be wrong with this car. Thanks!
I used tccrab's fix and had no trouble since.
http://www.zr1.net/forum/showthread....=dreaded+start
Daniel
Daniel
Starter Relay Tricks
Daniel
Daniel
The information is ALL here with a modification of tccrab's original two methods making Pin 87a NOT HOT at any time.
Starter Relay, Wiring Harness, and Plugs Tricks
That reference is dated and not the best method. tccrab updated that much later and I updated it even further here for CF. The cranking wire is now the purple wire from the ECM vice yellow wire from inside the vehicle.
http://forums.corvetteforum.com/c4-z...-splicing.html
I basically used the same procedure but ran the wires in a way that no wire cutting or splicing is needed
It appears you have accomplished this with the original design in place
Thanks for the information
