Can someone talk me out of buying a ZR-1?
#121
That was the advertised power. I have original documentation from Lotus with a dyno sheet showing 445 CHP at 6600 rpm. It is signed off by Lotus with the statement that the "advertised power" will be 405 hp. What documentation do you have?
#124
Received 3,043 Likes
St. Jude Donor '05
The LSx was cheaper to build lighter and smaller 2 reasons GM went to them over the DOHC.
Take a good look at the mains on the LT5...northstar and then an LSx.
See the similiarities? Think GM had knew something worked well and kept on with it maybe?
Yes it started there.
#125
Moderator
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23
Enough of your BS. Trolling won't be tolerated here. You can prove your not during the week of May 15 @ Beech Bend Dragway during the C4 Gathering in Bowling Green KY. Talk is cheap.
