C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
When shutting car off sounds like marbles in a can
Old 08-09-2013, 09:49 PM
Lucky86
Lucky86's Avatar
Default When shutting car off sounds like marbles in a can
Please ,tell me its normal with a zr1, every time i shut the car off , i get a sound from the motor, like you were throwing a handfull of marbles into a metal garbage can.
Old 08-09-2013, 09:52 PM
ghlkal
ghlkal's Avatar
Finalist 2020 C4 of the Year - Modified
2018 C4 of Year Finalist
Likely the dual-mass flywheel.
If so, it's normal (I think -- at least mine does it too )
Old 08-09-2013, 09:55 PM
Lucky86
Lucky86's Avatar
I was praying i didnt get a response like- that noise of marbles in a garbage can ,is the first sign of the lower end letting go, and a full rebuild is needed.
Old 08-09-2013, 10:47 PM
zr-1 guy
zr-1 guy's Avatar
Originally Posted by WICKEDFRC
If it is a 6-Speed, this is because teh transmission is in the rear and it takes a second (or two) for the torque tube to stop spinning.
Next time before you shut off engine, simultaneously press in the clutch pedal with your left foot (releasing the clutch from flywheel) while pressing the brake with your right foot.
No more marbles.
.....you do know what section you're in right?
Old 08-09-2013, 10:52 PM
WICKEDFRC
WICKEDFRC's Avatar
Received 1,652 Likes on 738 Posts
Oops. My bad. Sorry, I now know.
Old 08-10-2013, 12:17 AM
zr-1 guy
zr-1 guy's Avatar
just having fun with ya
To When shutting car off sounds like marbles in a can
Quick Reply: When shutting car off sounds like marbles in a can
