look ma, got no teeth!!
well we yanked the pumpkin yesterday and and first we were scratching our head. ring gear looked just fine and it still turns over relatively smoothly. found one dry ujoint at the back of the drive shaft.
we look a bit closer and found a couple of teeth from the pinion gear sheared cleanly off. not junk in the oil, just busted off
83K miles of sheer torture was enough for that poor pinion (it has been through hell)
the new rear is going in today thanks to Phil and Gibby, and the LSV will be back on the road !!
it's pretty amazing that the gear busted just driving it (as intended I might add) on the street with "enthusiasm"
I believe a nice 2nd gear hook on a WOT power shift did it. no spinning of the tires, just pure LSV flat gettin it
oh well, if the rear can't take the output, time for a stronger one!
the new rear has the nice 4.10 viper super dana gears which are quite a bit more beefy than stock.
I'll post some pics of the carnage and a comparison of the rears and gears once we tear down the pumpkin to replace the ring and pinion
Received 1,864 Likes
Those old headsets just aren't as stout as the newer stuff. I hurt the 4.27 cogs in my 90 ZR-1 at Beech Bend,back in 2000,on a 2nd gear power shift. Got into a smidgen of wheel hop and that was all it took.
Glad to hear you found the problem,Ron.
I drove Lance Millers car which I believe has 4.33 gears car runs really well
