Car Audio in the ZR1
I'm a little torn on this subject. My current stereo does not work, and honestly it is a bit annoying. Short drives are not a big deal. The exhaust sounds so good, but on a longer trip it will be annoying.
It has the stock radio in it now. I have been thinking of having it fixed which would consist of the Headunit and CDM that needs to be fixed. I also would have an AUX-in added at that time in order to use pandora in my car.
What is everyone's thinking on keeping the stock radio in the ZR1? I know these are low production cars and might actually go up in value someday(probably not mine because of the mileage). Would having a newer style radio a bad idea? Is there anyway I can use the stock speakers for a while until I can afford to replace them with aftermarket units?
I am not so sure the CDM would fail...but maybe so.....that CDM is hard to remove and more difficult to replace correctly
I just send the CD player/radio to Doc Dons for upgrade.....and replace speaker amps with Nissan Max amps Bose Speaker Amp Options TIPS
Note:.......I have removed and replaced a couple CDMs thinking the CDM was the issue (NOT the issue). I have also re-installed CDMs that were just sitting freely above and on the passenger side hush panel. No sound is often related to failed speaker amps. Lets see what others say as there are many very interesting sound system conversions that have been installed replacing the Bose.
Also....you can e-mail Doc Don and describe your symptoms for an expert opinion
Also.....do not break the tabs (one tab each side that is bolted (10 mm) to the CDM) on the plastic plate under the CDM or the tabs holding the CDM in place) that plastic plate has the inserts for holding the various electrical connectors. You can remove the electrical connector inserts by using needle nose pliers inserted above the plastic plate squeezing the tabs on the insert for removal from below the plastic plate. Then re-install the insert on to the electrical connector re-inserting the insert (with electrical connector attached) into the plastic plate when you are finished.
Currently when I press a button for AM/FM/CD it does nothing on the headunit. It just displays the time as 1:00 PM. All fuses are good as well.
I have no idea what your auto DIY experience is but I can tell you this,removing the CDM controller will be one of the most difficult jobs you will ever do.If mine dies again Ill spend the cash and tear it all out which in a sense would be a waste of money because the stock stereo kicks *** but anything to keep from removing that bastard CDM controller again.
YANK it the car is no NCRS show car with 11 miles on it so enjoy. A lot of us have moved on to Bluetooth, voice command, nav units etc.
Received 1,867 Likes
NCM Lifetime # 982
They're not worth much any way's
A total rip and replace could be down the road. Should I just send my CDM module in to get worked on and go from there?
Is there a good tutorial to remove the CDM?
I got a good used tuner (cdm) for $60. The speaker amps can be cheap- probably the speakers themselves are ok. expect the CD player to not work as well.
it's under the passenger side kick panel up inside the dash a ways. you can pretty much unscrew most of it without a ton of trouble, but I ended up getting impatient with one hard-to-reach plastic mounting tab- just snap it off and use velcro on the reinstall- it just makes the job 10 times easier. like others said- if you aren't a super low mileage NCRS candidate, just take the shortcut.
the later cars relocated that tuner to the storage bin behind the seat. it was factory installed with velcro there. That's where i got the idea.
no, I meant breaking the cdm mount by force so it doesn't take 7 hours to replace and half the dash board taken apart.
but just leaving it in the depths of the dash and unplugging the head unit would be a shortcut too (and maybe a better choice in your case). One of the major vette parts places (Zip) actually has a compatible head unit that bypasses the tuner, but allows the use of the original 1 ohm bose speakers and amps. This would likely be the most economical semi-replacement.
The stereos aren't double din format, but the kit comes with a filler plate and the other stuff you need to plug it in.
http://blog.zip-corvette.com/corvett...-1984-1996-c4/
http://www.zip-corvette.com/catalog/...category/7894/
Theres a guy on Youtube taking one out but the easiest way,if there is one is to take out the seat-tracks and lay on your back.
