New Alternator Pulley Smaller than Existing Unit?
I have had intermittent issues with the alternator. I decided to replace after and second episode with a near dead battery. I discovered the pully on the existing unit is quite large and it is very difficult to install and replace the serpentine belt. I had to use pliers to walk the belt off of the pulley. I purchased a new 140 amp Powermaster (I have heard good things about these) unit from Summit. The pulley on the new unit is smaller. It will probably still work but need to do a test fit. Should I swap pulleys? I am concern that the new unit will not behave properly if I use a larger size pulley.
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
It is interesting that Powermaster and others do not list pulley diameter in the details section. I would think this would be critical information...
