what shocks are you using
it is getting almost impossible to find part for the fx3 set up on our cars plus if you do it costs an arm and leg . what shocks are you guys going with if you abandoned the stk set up .
not really that hard to find, but the rebuild stuff seems like it's getting more scarce
I have a set of early and late model shocks they are grooved for coil overs and work just fine without them, or you are ready to just add the kit
PM me if interested I have a bunch of actuators and the early control modules
you can switch the shocks and control modules as the wiring is the same
I use a DRM shock controller and I really like the 93-95 shocks as they are a bit softer with the coil overs
I have an early set on the car right now which will be coming off soon so I can go back to the late model shock which react a bit faster
