Clicking/popping noise on left turns
I have noticed when my car is being driven for the few blocks that when making a left hand turn I hear a popping/clicking noise from the rear of the car. It sounds similar to when I am letting the clutch out, but happens through out the turn usually when under a little throttle. Right turns there is no noise at all. I may setup my go-pro and try to get some recordings of it.
Scott
I changed the engine oil, transmission, and rear diff fluid not even a year ago. I used Mobil 1 75w-90 in the rear diff.
I did not add any LSD additive. I was under the impression its not needed with Mobil 1.
Scott
I also thought that Mobil 1 had the limited slip conditioner, but I was told that I still needed to use the GM additive. It definitely solved my problem within about 10 miles after the change. If the fluid is good (and you don't need the additive), then you may be experiencing a different problem than I had.
Scott
Scott
I originally thought maybe U joints for the driveshafts. Wheel bearings when they go bad usually make a whirring noise. I'll see if I can get a video of it.
Scott
It sounds like it could be the bearing or the u joints. I just bought all new bearings. I know the passenger side bearings had some play, I don't know about the driver. Some people have said it is okay to have some play. My understanding is that there should be no play in wheel bearings.
Here is a video of the noise.
It is around the 2 second mark. Almost sounds like a slight rubbing noise.
Is there anyway to confirm that my U joints are bad?
I would try the additive first. You would not believe the noise I have seen different cars make with out it. Especially since you did not put it in after the fluid was changed. Cheap and easy. It will take a little bit to work its way in.
Is there a sure way to test or evaluate the U joints before trying to remove the halfshafts. Is it true that the camber bolt needs to be removed in order to get the halfshaft out?
Found this youtube video. Looks like I can apply this to the vette.
I replaced both of my rear wheel bearings, that did not fix the issue. I still have a squeaking/chirping noise when going straight under acceleration. Sometimes on deceleration there is a noise as well, but much less noticeable.
This must be the U Joints. When I had the car jacked up I didn't notice really any plan in the u joints, but then again it wasn't on the ground.
