clutch hang up
clutch hang up
I have been reading zf docs site about clutch hang up. Occasionally it will be harder to shift to first after waiting at a stop light. ZF doc explains how certain slave cylinders could be defective, as I replaced my master and slave cylinders a few years back. Seeing how I think I installed a defective wagner slave cylinder, where do I get a correct one from, how do I know if it will be built properly? Thanks everyone
NCM Lifetime # 982
Have you changed out the clutch fluid lately ??
you could have a bent clutch fork . unless you really know what to look for with the clutch fork you might think it is ok . the other part that might look at is the pivot ball . bill taught me long ago when doing clutch change to look at everything not just the flywheel pressure plate and disk .
