adding a shift light
Pro Mechanic
I believe that there is already a "shift" spot in the cluster. That would be MY "OEM looking" choice.
Another popular alternative is hiding it in the AC vent. Access to the tach wiring is on the C100 connector (I have a 90, so I'll refrain from specifying which pin and refer you to your FSM)
Pictured is the Raptor light running through its initial start-up test routine, hidden in the AC grill. It is all but invisible until it is triggered, and then it is so bright that you don't need to take your eyes off the road to see it!
