EZ Pass and ZRI Windshield
I doubt that any of the transponders will work with our windshield. I typically row down the window and hold the Fastpass out the window.
I have a Valentine 1 that sits in the cutout and I just put the I-Pass (our version of EZ Pass) in front of it and push the radar detector tight against it. Works fine. You can just see the detector and the I-Pass in this picture.--Bob
I was thinking of sticking to a piece of plexiglass and suction cupping it in the cut out, then I pull it out when I want to. I could probably mount it inside a fender as well. On my bike its mounted in the the fairing.
You will be adding another layer for the transmitter to have to transmit through with the plexiglass option. Give it a whril as its easy enough to test and let us know if that works. If it does it might be an option others may want to use
