Autocross ZR1
Pro Mechanic
More info would help. What class?
You doing this for FUN, or to WIN?
I'm thinking SCCA Solo B Stock Class. I'd like to WIN, but at 63 years of age I don't think I'm as fast as I once was. I was very competitive in my 20's, 30's and 40's with several Porsche's, BMW's, Alfa's and even a Chevrolet Citation X11.
Pro Mechanic
To win in B stock, you'll need tires, shocks, like-new suspension bushings etc, and probably something other than a ZR-1 (it's heavy).
To have FUN, just go there on your street tires, set your shocks to "sport" and rip it up!
Before doing an autocross you need to understand the workings of the radiator bypass system. You can do a search on this forum or go to the ZR 1 forum and search there.
Tyler
Tyler
Pro Mechanic
First I've ever heard of this feature. How did this thing run for 24 hours at WOT with such a feature?
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
It bypasses at around 6000-6500 RPM's to much water pressure for the plastic side tanks on the radiator.
Pro Mechanic
Lot of conflicting info here. 5200 RPM, 6500....
I don't think the RPM matters too much. When it by passes, it's bypassing enough water to limit peak pressures....but there is still a LOT of water going through that radiator. Probably not going to over heat, unless you run it at redline for extended periods, in extreme conditions. Can't imagine how this could be an issue for a 30 -60 second auto x
Some autocross courses could last 90 seconds, but I don't think the car would overheat. as coolant will mostly be flowing about 1/2 the time dpending on gear selection and how tight the course is.
Pro Mechanic
The bypass feature was a GM design because Lotus wouldn't back down from their 25 GPM/100 HP standard water pump spec and GM refused to have a ZR-1 specific radiator...another GM screw-up on what could've been a much better engine had they left Lotus alone. If that engine had been allowed to "be all it could be", today we could have a 6.2L "LT5" with 650 HP without a supercharger. Direct injection and VVT would maybe get more than 650 HP and the engine would be the same weight/size (outer dimensions) as the LT4 in the C7Z06 with a far superior HP curve and better MPG. Sorry, I let my imagination run loose with a little "what if"...
Oh yeah another stupid design is the oil cooler, it has a thermostat that does not open until the oil temp is 250 deg. If you see that temp it is probably too late to be effective. Once you go full water bypass it gets very hot very quickly.
Graham will be at BG ask him, he helped design the Lotus side of the system.
Do your research then you can adjust your driving style to the known limitations.
Tyler
Pro Mechanic
I think that you're creating a concern where there isn't one. How many well maintained C4Z's have over heated at an autoX? Glass Slipper hasn't had any issue in 22 years...
No way, the system does not bypass the radiator 100%. What would be the benefit of that?? The purpose is to save the radiator from over pressure due to the high pump volume. I know you know that. So they put what is essentially a pressure relieve valve in the circuit to bypass flow beyond what the radiator is capable of handling. Beyond...not all of it. Based on the believable numbers that you posted from THIS POST, It would seem that at max RPM about up to 40% of the coolant is bypassing the radiator (if the figures you posted are correct). Not enough to overheat an engine in any kind of AutoX that I've ever been part of. The radiator is never closed off by this bypass system...it's always wide open, so there is nothing to stop or slow the water from circulating through the radiator. It's simply that at some point (the ~60 gpm point, according to your post), the radiator becomes a limiting factor to coolant flow, the rising pressure on the inlet side begins to force the "pressure relief valve" open, porting some coolant back to the inlet side of the water pump. A this point, coolant flow through the radiator remains static as RPM increases, while coolant flow through the bypass portion increases. This could be a slight concern at a big track (although I still don't see driving around a real track at a constant 5500+ or whatever RPM)...but not at a 60 (or even 90) second autox.
Recommend reading the following post: http://www.zr1.net/forum/showthread....adiator+bypass note at the end of the thread is a post by the GM Engineer who designed the system email him.
Tyler
Pro Mechanic
Well man, I'm not "thinking" or "guessing".
This isn't that complicated. Look at this picture (I know that you've seen it before)
You see the thing w/the green arrow pointed at it? That is your "pressure relief valve". See the spring behind it? Pushing against it? What do you suppose opens that valve/spring? Water pressure. Where does that water pressure come from? Resistance to flow through the radiator.
Now, what device "closes" the flow to the radiator? Look at this diagram.....where is that device?
The upper radiator hose (the one going TO the radiator) is wide open, all the time....so what device closes off flow to the radiator? None.
Now let's apply some common sense: the point of the bypass is to limit pressure to the radiator, right? So there is zero need to STOP flow to the radiator, only to limit it. The way that I've described it does just that, while still maintaining a good amount of coolant flow through the radiator. The way that you're describing it, would over heat an engine in ~30 seconds. How many track-goers here have over heated their engines that quickly at a track day? I'm guessing (NOW I'm "guessing") none.
As for the link you posted....another thread arguing about thermostats?? No where in that thread did it rebut what I'm saying. Just LOOK at the thing. It's self evident how it works.
Tom,
You should research this.
https://history.gmheritagecenter.com...R-1_Prototypes
One would gather Tyler has a fairly good understanding of the LT5.
He restored and ownes one the cars pictured in the above article.
Pro Mechanic
Tom,
Show me the valve that closes off flow to the radiator.
EDIT: THIS ARTICLE from the same web site if far more relevant as in the 3rd paragraph it talks about ZR-1 cooling criteria and performance:
this new Corvette program developing the engine cooling system to handle the hot Arizona ambient temperatures as the engine ran through its entire range of operating parameters. It had to run cool at 600 rpm idling all the way to Wide Open Throttle at 7000 rpm during maximum speed testing on our five mile circular track
What does ^that^ prove? Nothing, but it's way more relevant to the discussion than the link you posted. No car is going to meet that test criteria with the radiator completely eliminated from the cooling loop.
