C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Rare Dark Purple Metallic ZR-1 F/S
Old 03-31-2016, 10:37 AM
ZR1Bob
ZR1Bob's Avatar
Originally Posted by Hib Halverson
It has not had a "500+" package done. The "package" it has is the "Street Skinner" engine upgrade once offered by Automasters which was the shop owned by the late Jim Van Dorn,one of the pioneers of LT5 performance enhancement in the early days of the ZR-1 hobby. Generally a Street Skinner had ported heads, housings, partially-ported plenum a bigger throttle body, reset cams along with "blueprinting," Typically, Street Skinners, had headers and were good for 480-500-hp. Mine did not have headers but did have a few additional modifications beyond the standard "Street Skinnner". The car ended up making 413 at the wheels SAE-corrected which, using a 18% correction worked out to 503-hp. The engine was done in the late-90s and has had 51,000 miles put on it since the overhaul so I imagine it makes 475-490-hp at this point......
That is exactly the horsepower my Haibeck 510 package made at the dyno--413-- partly because it lacked the Fidanza lightweight flywheel to which Marc allocates about 15 HP. The mods done by Marc are very similar to those done to Barney's engine, and those mods leave the engine as durable and reliable as a stock one. So mine was also making a bit less than the advertised 510 HP, but sure was strong regardless, as I am sure Barney is as well. What a great buy for someone. Sorry you have had a problem with some potential buyers. Hopefully there will come to their senses and reconsider. --Bob
Old 03-31-2016, 11:11 AM
Hib Halverson
Pro Mechanic
Pro Mechanic
Hib Halverson's Avatar
Received 1,135 Likes on 592 Posts
I've run a lot of chassis dyno tests over the years and, indeed, it's interesting that our two cars made the same number at the wheels.
What kind of dyno was yours run on?
What correction factor did you use?
One difference is that I have a light flywheel, a McLeod aluminum wheel, to be specific. The other differences are I "ported" my exhaust manifolds and the cat inlets by removing all the welding garbage left inside the manifolds. I deburred and smoothed the manifolds' port entries and I deburred and smoothed the inlet of each cat. Finally, I had a special exhaust system built using a mix of stock and Flowmaster components.
Old 04-01-2016, 10:48 AM
ZR1Bob
ZR1Bob's Avatar
Hi Hib--
Here is the dyno sheet. that's all I know. Don't know if marc cleaned up the headers but he might have. I think when he dyno'd the engine it had headers, a Corsa exhaust and no cats.--Bob
Old 04-01-2016, 03:58 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
Hi Hib--
Really interesting info., "ZR1 Bob". Thanks for posting.
We both tested on a DynoJet.
My numbers were SAE Corrected.
There is nocorrection info on yours.
My numbers used an 18% correction for parasitic loss.
You're used a 15% correction for parasitic loss.
I used 18% because that's what GM Powertrain told me the C4 manual driveline consumes.
In any event, the two cars were pretty close.
Old 04-01-2016, 04:04 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
About noon today, Pacific time, Barney was SOLD.
Can't say who bought it until the buyer gives me permission to post the name.
Old 04-01-2016, 04:06 PM
-=Jeff=-
-=Jeff=-'s Avatar
Congrats! So do you now have a list of parts to sell?
Old 04-01-2016, 10:32 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
Yes, I do...a very long list, however there are a couple of people who asked some time ago about specific items on the list. I'm going to give them "first shot" on a couple of things. After they have their chances, I'll post the entire list.
Old 04-02-2016, 10:08 AM
93Rubie
93Rubie's Avatar
Glad Barney found a good home. Someone got a heck of deal IMHO.
Old 04-02-2016, 11:39 AM
randy ransome
Support Corvetteforum!
randy ransome's Avatar
Winner 2020 C4 of the Year - Unmodified
2018 Corvette of Year
2017 C2 of Year Finalist
2015 C4 of Year
Congrats Hib on the sale. I hate we have to let these great cars go for so little money. At least I drive mine to get the Per-ma-grin.
Old 04-02-2016, 12:21 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
Barney's new owner did, indeed get a heck of a good deal because it was, clearly, a buyer's market. The new owner will give Barney a good home and will contribute much to the 2G ZR-1 hobby.
Quick Reply: Rare Dark Purple Metallic ZR-1 F/S
