looking for 19# steel flywheel
NCM Lifetime # 982
I would give Jerry's Gaskets a call. He'll hook you up.
Just FYI, I believe Pete Polatsidis is using a DRM, 19#(?) steel FW. However, Fidanza's aluminum FW comes in close at 13# (IIRC), and has bolt-on friction plates that can be replaced if need be. Just a thought.
IDK if there's much practical difference between the 13 and 19 pound FWs, especially when compared to the 46# dual-mass (stock) FW; the gist of the reduced mass FWs is realized by either of the two single mass (as they're reasonably comparable weight-wise, methinks). My point being, the renewable friction surfaces of the Fidanza was a selling point for me. (And, I love the added 'snap' in acceleration allowed by the reduction of FW mass, especially in lower gears!)
FWIW...
FWIW...
I suspect that the heavier steel, will rattle slightly less, simply b/c of physics. That heavier mass is slightly less affected by engine firing pulses. In my car, the exhaust mostly masks that noise.
WP,
The heavier steel FW will certainly have some more inertia, but don't forget the stock dual mass was significantly heavier and w DM to absorb the engine pulse. Careful idle and part throttle tuning goes a long way to minimizing the uneven engine pulse that leads to the ZF rattle.
I have a fidanza right now . the reason I wanted to go to the 19lb ,I want to switch out my 410 gears and go back to the stk 3.45s and thought that the little extra weight would help with the take off from the stoplight . .also I don't plan on going to the drag strip much anymore.
I'd swap pumpkins w you.
Mike told me the custom steel FW I have weighs about the same as the 4+3's. I absolutely LOVE the ZF6 w/3.54s in the car for all around street driving. I still need practice launching from lights, tho. You obviously understand inertial effects on real world driving.
yeah , I know not too many zr1s out here. I am going to bill boudreaus later this week to install a 28 lb flywheel.my 410s were done by corey and have the viper gears . if there is anyone living in the phoenix area that wants to trade pumpkins while I am there pm me .
Pro Mechanic
Pro Mechanic
There are number of sources for aluminum flywheels. I have a McLeod aluminum wheel in my '95 which has been there for 15 years. I have the stock 3.45 axle and have never needed more flywheel mass that that for around town driving.
Also, I've heard that there is a lightweight. nodular iron flywheel from a Camaro that fits an LT5.
