Regular Fuel pressure
While driving my 1990 Zr1 down the highway it quickly began to lag than completely die. It would not start again, sounded like it almost wanted to would crank and fire for a sec than die. I checked my fuel pump fuses and check the pressure which was at 0. So I swapped out a fuel pump. Car would still not start and had 0 pressure. Heard the pumps or just pump kick on but still nothing. Pulled the assembly again touched every connector and hose and shoved it back in. Darn thing fired right up at 47ish PSI at 3k it drops a bit to around 45 PSI and when you shut off the car its around 35 PSI. I plan on swapping out the other one out and doing a full rewire but was just curious as to why only replacing one pump would fix the car? Are these numbers good? Think it might of had something to do with connectors being loose?
Jumper to avoid being stranded with a failed Primary Fuel Pump
As described in the Link above........
"If number 1 fuel pump fails, the LT5 will start properly but then die after a short period of time. When the engine is cold, the period may be almost a minute. When the engine is at operating temperature the engine will die immediately after starting."
"This happens because the ECM energizes BOTH fuel pumps on engine start. So the Secondary Fuel Pump supplies fuel to the injectors while the primary pump does nothing. Once the engine is operating properly, the ECM turns off the Secondary Fuel Pump and the car stalls."
