no crank over help needed
3 times now the car would not crank turn the key push in the clutch nothing radio shut off but no crank. We push start the car no problem shut off and it starts again for several trys. what do I need to look at I hear this is a problem with the zr1
1992 zr1 453
1992 zr1 453
Does the security light go out when you insert and turn the key?
Check the clutch relay switch under the dash, I think it's a big yellow plug. It should show continuity when the clutch is pressed down.
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Starter relay issue. Very common among the ZR1s. See sticky for fix, and you'll never have the issue again. Tons of threads on this topic in the search function too.
Starter, Starter Relay, Wiring Harness, Battery, and Plugs Tricks
Electrical Ground Connections and Installing Starter Relay
