shock help
shock help
I have fx3 shocks that are giving me a fit would like to change out to a more performance ride but not go to coil overs and run it on the autocross does anybody have a suggestion I tryed koni adjustables from my lt1 setup but they don't work
Pro Mechanic
I would get any of the higher quality "coil over" shocks...w/o the coils. QA1's. Ridetech...something like that.
I'd be interested to hear what didn't work for you w/your Koni's? I have them on my LT1 and don't love them either.
Former Vendor
http://www.ridetech.com/store/muscle...ures_hash=V363
Rodney@ridetech (11-11-2015)
Pro Mechanic
I would be interested to hear what the OP thinks about his, but I feel mine don't have enough compression damping, especially in the rear. I'm on BASE, 92 suspension.
The Koni's where setup for the 89-91 Z51 spring rates. They might help with the base springs but I suspect the shock not being calibrated for your springs is the real culprit. Which would make sense if you don't feel you have enough compression damping. The spring is moving more than a stiffer spring would.
Pro Mechanic
Yes, that does makes sense to me...and I'd wondered about that.
Springs are on "the list".
St. Jude Donor '11, '14
You can have the fx3 redone to the more aggressive movaca revolve. Call Bilstein in Cali. They can tell you what they do to them. I use them on coil overs and I love them on the track.
Robin
Robin
Pretty sure there are GM bars in 32mmsolid I know I ordered the 32/26m solid bars for my 93 straight from GM can't recall what years used them (think zo7 package used 32 solid up front can't recall the 36solid rear bar). Wouldn't reccomend the 26mm solid rear though unless you have the tire/suspension setup it definitely made power slides all too easy! Vbp should carry a 32mm bar or even bigger not sure.
I am going to the QA1 double adjustable shocks . they are about the same price as new fx3 shocks .then I am done . they have 276 different settings .with the fx3buy new shocks then one has to worry about the actuators . which can be another 800. jmho
