C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
rearend help needed
Old 11-11-2015, 11:53 AM
bvectra
bvectra's Avatar
Default rearend help needed
it appears my clutch pack is not working right in my 92 zr1 the right wheel does most of the driving the left doesn't do much now if i rebuild build it should I just replace the clutch pack or go to after market stuff for better racing .
Old 11-11-2015, 12:33 PM
Zrxmax
Zrxmax's Avatar
Rebuilding is a good option because then you will know exactly what you have and hopefully some kind of warranty. Plan B could be to simply
source another rear end so you have a spare and can keep the car operable while maintenance / rebuilding is being performed.
I have 2 rear ends for that last reason that allows me 2 different ratios for different uses.
bvectra (11-11-2015)
Quick Reply: rearend help needed
