90 ZR-1 Z Industries Hot Chip (E Prom)
I have an eprom/memcal done by Ron Zimmer at Z Industries for a 90 ZR-1. This was for a nearly stock car with light mods such as free-flow exhaust and air intake. It eliminates CAGS and turns fans on at lower temp also if I remember correctly.
My friend who owned the car claimed to really notice a difference and purchased another chip from Ron when he bought his '94.
If you have any questions, call Ron at Z Industries in California with the chip number (see photo) - he probably still has records on it.
$130 delivered
$130 delivered
I have an eprom/memcal done by Ron Zimmer at Z Industries for a 90 - 91 ZR-1. This was for a nearly stock car with light mods such as free-flow exhaust and air intake. It eliminates CAGS and turns fans on at lower temp also if I remember correctly.
$175 delivered
$175 delivered
Also, 90 ZR-1s used an external knock sensor circuit. 91-95 knock sensor
circuit is on board the prom itself.
Just to clarify, this prom won't work for a 91. The calibration for each model year uses a different format or is laid out differently. The values may be the same, but where the values are addressed in the calibration is very different.
z industries chip
I have one of his chips in my car and it runs great. They did a comparison test against several other tuner chips and the z industries chip was the most aggressive of the bunch. It is not a custom chip but it does work well. The previous owner of my car was a dentist who was in to performance and would occasionally track my car and he tried several chips and kept this one. Good Luck with your chip.
ed ramos #3028
ed ramos #3028
ed ramos #3028
ed ramos #3028
Pro Mechanic
Pro Mechanic
Zimmer did the original cal in my 95.
I ran it for many years until I had trouble with the CA smog check's NOx limit.
Ron Zimmer then burned me a cal which reset the EGR valve enable from 17-mph to 14-mph and that fixed my Smog Check problem.
Zimmer did some good stuff with LT5 cals back in the day. His chips are still good choices today.
