Diagnostic Grounding Plugs for 90-92
Pro Mechanic
Pro Mechanic
A full set of Gordon Killebrew's diagnostic "Grounding Plugs" for 90-92 ZR-1
If you don't have a scan tester and use "flash code" diagnostics, this grounding plug kit is for you.
No more paper slips or jumper wires. Just stick the plug in the ALDL and turn the key on and watch the appropriate service light flash codes.
This set fits the 12-pin DLC on 90, 91 and 92 ZR-1s and has never been used. Extra added attraction: the ECM plug supports Corvette all the way back to 1982.
Killebrew's web site has these for 45 bucks.
You can have this set for SOLD
