Performance Chip for 93-95
Pro Mechanic
Pro Mechanic
Performance Chip for 93-95 which helps reduce high NOx
For sale: aftermarket calibration chip for a 93-95.
This is a custom-calibration, done on a chassis dyno for a 93-95. The engine it was for had an Automasters "Street Skinner" performance enhancement package which required custom calibration.
The cal was one of the last done in the early-'00s by famed LT5 aftermarket calibration engineer, Ron Zimmer (now retired) of Z-Industries.
It is intended for use with a stock displacement engine which is modified on both the intake and exhaust sides. You need to have ported heads, ported housings, a ported plenum and reset cams along with significantly reduced restruction in the exhaust for this chip to work best.
This cal has fuel and spark schedules appropriate for that level of modificaions. It, also, has lower fan-ons, CAGS disabled and is intended for use with port throttles. Premium fuel is required with this calibration.
A useful feature of this chip is a fix Zimmer developed for 93-95 cars which are flunking an "I/M 240" emissions test because of high oxides of nitrogen (NOx). I/M 240 tests usually have an initial speed of 15-mph where it takes the first exhaust sample. The stock calibration doesn't enable EGR until 17-mph. which means high NOx below that speed. This cal is revised with a 14-mph enable speed to reduced NOx emissions which helps the car pass a NOx test.
Price: SOLD postpaid anywhere in the U.S.
email finspeed@netmotive.net
