WTB ZR1 1990, 70K miles, what the heck should I be inspecting?
I an NOT familiar w/ the King of the Hill ( other than media write-ups)
I'm looking at a clean 1990 ZR1 with about 70,000 miles
I'm a little apprehensive on a 26 year old car with tons of unique electronics... electrically controlled suspension and other state-of-the-art goodies for the time.
car started but has a low RPM and up stumble/hesitation ... fuel pump possibly?
what would YOU inspect or should I just take it to a dealer?
I'm in San Diego... if you have suggestions for dealer or third-party inspector.
Thanks in advance.
Thanks in advance.
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Check out this site lots of great reading for ya. and good luck.
http://www.zr1netregistry.com/Market...yersGuide.aspx
You may also want to read the sticky at the top of this page and in the net forum. I'm sure others will post up and you may even find an owner who would be willing to look it over with you, it a very tight group.
Finalist 2020 C4 of the Year - Modified
I approach this on three levels
1 – standard “used car” issues
eg, clutch, tires, brakes, paint
2 – C4 Corvette issues
eg, weatherstripping, headlight door motors, clutch safety switch
3 – ZR-1 issues
eg, secondary vacuum pump, windshield delamination
You’re right, this is a 26 year old car, even if it is a ZR-1 Corvette, so pay attention to areas 1 and 2.
For 3, you’ll discover a few common issues. For example, the dreaded “no start” and the common “bad injectors.”
The “stumble” could be bad fuel pump(s) [there are two], or bad injector(s) or ?? -- I would guess bad injectors
As far as inspection, ask if there’s a ZR-1 person nearby who could go with you to see it; otherwise ask for a good shop (I agree I wouldn’t just take it to the Chevy dealer unless they have a tech who understands C4 ZR-1s)
If something doesn’t feel right or look right, it isn’t. If you discover other issues, write them down and post them here (although it is tough to diagnosis at a distance :-)
Good luck
3 – ZR-1 issues
Good luck
