Secondary Vacuum Pump
8th Gear
Hi
Just got a 92 zr1 one and was hoping someone could answer a question. Upon checking the vacuum pump I found the motor in it rusted and not working. I have another one ordered but was wanting some clarification. Does this pump keep full power from operating or does it just hinder it from working to its full potential? Ive googled it but can't find any thing directly stating this.
Hi
Rich
8th Gear
One of the first checks for a vacuum pump that continues to run at all times is the functioning of that check valve. Just pull the Plenum vacuum hose between the two runners on the Drivers side and hold finger over pulled vacuum connector (the vacuum pump should stop running immediately.
Failed Vacuum Check Valve TIPS
Yes.....there are two sources of vacuum for secondaries (vacuum pump and Plenum vacuum). There is a check valve under the plenum that closes when the vacuum pump takes over with wide open throttle (Plenum vacuum drops at wide open throttle). Without that check valve the vacuum pump (if you have some vacuum leaks) would be running all the time while cruising with relatively high Plenum vacuum. With that check valve operational, the vacuum pump is not required when cruising to maintain sufficient vacuum should you step on the gas. But once you step on the gas the vacuum pump takes over as Plenum vacuum drops .............
The Secondary PT Pump is there to supply vacuum under WOT & will keep up with small leaks, but not major leaks.
