ASR Service / Service ABS
It could mean your ABS unit has failed but check your brake master cylinder fluid level first. If its low or out you may have air in the system and it will need to be bled
Another cause forthe ABS light is the sensors at the wheels could be dirty. They're magnetic and pick up debris from the road.
You will need a Tech2 to reset the code.
I had a relay fail on my ABS some years ago.
It lives behind the drivers seat underneath the storage area.
The relay itself is nothing fancy, just isn't made anymore and and is hard to find and very expensive.
It can be replaced with an off the shelf relay with a little fairly straightforward modification.
'Crabs
'90 ZR1 #792
'Crabs
'90 ZR1 #792
