C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
fuel injectors
Old 09-05-2016, 02:08 PM
chefsal
Support Corvetteforum!
chefsal's Avatar
Default fuel injectors
Hey Guys,
I am the second owner of a 90 ZR-1. I bought it two years ago with 12k. I now has 23k. Recently I ve noticed some skipping and hesitation when I lean on it. Its especially true when in full power and not has noticeable in regular power. There are no vacuum leaks and the plugs/wires are original. Can I Assume its the injectors at this point? If so is the only fix is to replace them? Has anyone tried techron or similar products? And if I need to change what else so I change while I'm at it?
Thanks Guys!
Old 09-05-2016, 02:45 PM
jay1055
jay1055's Avatar
Originally Posted by chefsal
Hey Guys,
Thanks Guys!
If they have never been changed it is time cleaners will probably not help?
Old 09-05-2016, 03:32 PM
Z51JEFF
Z51JEFF's Avatar
If they are original they will need to be replaced. Get the plenum gaskets and O rings while you're at it.
Old 09-05-2016, 04:01 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
Hib Halverson's Avatar
Received 1,143 Likes on 597 Posts
If the plugs and wires are original, I'd try changing plugs, first.
To fuel injectors
Quick Reply: fuel injectors
