restoration of Steel Blue 91 #391 ZR-1
#41
1994 Admiral Blue ZZZZZR1
Yep......about what I paid Safelite...........I had printed out all issues regarding how to remove the original screws and metal strips from a ZR1 just in case but the Safelite guy said he did not need the information as he had done several Corvette windshields before
#43
Raided the parts stash!
NOS LT-5 spark plug wires
NOS Throttle cover
Jerry's Permabond, PCV hoses Gaskets
Securty and remote system
Bill Boudreau's C Beam Plates
Bill B's shifter ordered....
NOS rear plate bezel
Carter's LT-5 throttle plate
Also:
New FIC injectors
New Delco coil packs
Vacuum lines
More to come!
David
NOS Throttle cover
Also:
New FIC injectors
Vacuum lines
More to come!
David
#46
You cannot go wrong with New PCV hoses from Jerry (no more Zip Ties) and C Beam plates from Bill. Block TB Coolant and then no need to put anythimg on those Plenum Gaskets and no need to torque those Plenum Bolts to maximum spec
If you block TB Coolant at Injector Housings....do not forget to place block in hose going to Coolant reservoir on passenger side. I use brass 1/4 inch hose splicer with one hose clamp on coolant side (The splicer is soldered closed). You can then remove all hose clamps on TB Coolant hoses along each side of Plenum or remove the hoses (I usually leave new hoses in place without hose clamps).
I am dropping a Blue Label Trans off for Bill (ZFdoc) shortly for rebuild and short shifter
#47
NOS Throttle cover
Also:
New FIC injectors
Vacuum lines
More to come!
David
NOS Throttle cover
Also:
New FIC injectors
Vacuum lines
More to come!
David
#51
This is my experience.....would be very interested in Demp's experience
Removing Cam Covers (Engine In Car) for Inspections of Camshafts
I have also removed the Heads with Engine In Car.....but you can almost lift what is left (the bottom end) out by hand. You have to have the engine removed for ease of Timing anyway.
#56
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
looks great Dave....where's our update?
#57
#58
Yes.......Amazing......three taps with hammer and those original Torx begin to move. They had to move as that was last resort......lol lol lol
