On the Straße again :)
After more than four years of storage
Well, the ZR-1 is finally back on the road after an extended break. I had a full service done, along with new Michelin tires. I knew it was going to be expensive when the garage showed me five pages of work that was done.
The car would not start after I took the picture, so that was another 300+ Euros for a new battery. So far, so good. It drives well, but I noticed the water temperature was on the high side of the scale on Friday. It was Okay on Sunday, but that was a cooler day. Maybe air in the system. I had new hoses and antifreeze put in. The green stuff, shipped all the way from the US since I could not find it easily here in Germany.
Only another six weeks and then it goes into winter storage. Hopefully some decent driving days during that period.
Ken
Ken
You may want to Jack the passenger side up a bit and open the coolant tank. Let the motor "burp" for a day to make sure the air is out.
Also, did they clean out the nose of the car for any debris on the radiator?
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Congrats, Hope you enjoy some time in the drivers seat.
KGV (09-20-2016)
KGV (09-20-2016)
Thanks,
Ken
Received 3,043 Likes
St. Jude Donor '05
Those gauges arent super accurate theres a way to get the real temp readout from the digital display been too long maybe someone can post up how to see it you may be running normal temps and not have a problem at all.
If you take the fans off and run a water hose through the fins from the backside that will help cooling quite a bit. Youd be surprised how plugged up they get, a vacuum or air hose doesnt always get it all. Sometimes you need both. Its kind of a pain but worth it.
Coolant Flow, Coolant Temp, and ZR-1 Photo
The Air flushed out of the coolant system ends up in the top of the radiator and from there being forced out of the coolant system to the Coolant Reservoir and on into the Coolant Overflow under Passenger Side Headlight as the coolant expands upon heating. As the engine cools down the Coolant Overflow tank will provide liquid coolant being sucked back into the Coolant System (the coolant System Retracts in volume as it cools). Make sure you keep the Coolant Overflow container under the Passenger Headlight at least half full of coolant. You can almost fill that container if you check when engine is HOT.
1. Push and hold the Fan Up and Fan Down Buttons (both at the same time) until you get 0:0 showing on the HVAC Display. Tap the Fan Up button several times until you get to 16.
3. Now Tap the Center Fan Speed Control Button once and read Digital Coolant Temperature in Deg C on the HVAC Display.
4. That HVAC Display will continue to show Coolant Temperature in Deg C until you make a new temperature selection after which outside air temperature will be displayed.
You are shooting for 90-100 deg C Coolant Temperature.
Very Nice Photo
KGV (09-24-2016)
