what is this connection...
i noticed the car was idling high.... dr google and i figured on a vacuum leak...
i found this connection unplug.
what is it ?
what is it ?
In your photo the second picture...............the round black item is the Fuel Regulator.
The BIG rubber hose is Brake Booster Vacuum.
You have a screw clamp on the PCV connector which if you get new PCV Connector from Jerry......you need no clamps....same goes with PCV main hose and two Injector Housing PCV Connectors. Jerry also has that Fuel Regulator Vacuum Hose New in stock.
done
out of no where car started idling high and developed a miss/stumble in the 2-3k range
i re connected it.... seems to have corrected those issues
only concern is how did that come off ?
hvac shows idle at 33 which is 825
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Some times the LT5 will have a slight backfire when starting, generally when it does it blows the fuel pump, PCV line under the TB body or MAP lines off
St. Jude Donor '16
Thanks to Henryr for this post and We Gone for the solution. My car backfired several weeks ago and I thought everything was OK. Then I started noticing high idle when I rolled up to a stop sign. It would eventually drop down to normal idle speeds. I decided to take a look under the hood to see if I could see anything disconnected. Finally, I see the connection photographed above had blown off during the backfire. Unfortunately, I don't have the rubber 90 degree elbow anymore so I could just hook it back up.
I just ordered a new connection from Jerry's Gaskets.
It's great having this forum as a resource for all things ZR-1.
Mike Boggs
94 Admiral Blue/Black
Mike Boggs
