is there a pic of the motor that shows the various little black hoses and clamps. some have clamps, some don't on mine.
henry
Henry.........you have to tell me if you are talking vacuum lines, or coolant lines.......on my Zs I always Block TB Coolant at the Injector Housing so those Throttle Body (TB) Coolant hoses have no clamps just to maintain looks (normally ALL coolant hoses have clamps)
That top rubber hose in your photo has a screw clamp as that is a TB Coolant Hose going to the TB.
The other lower hose connection with hose screw clamp in your photo is the PVC Vacuum Hose which on my Zs I use New Rubber Connections and those new hoses/connectors do not need clamps.
The Larger lower hose in your photo has no clamps and is the Cam Cover Vent Hose (one on each side).
If you look through the many posts in the Sticky at the Top of this Section or click on items in my signature you will find photos of everything and anything you might have questions about
