134 or not to 134, that is the question?
Zen Vet Master Level VII
My AC system is not functioning at the moment. That's Ok as it is cooling off in Texas, but I'd like to have that "in the mill."
Becasue the car is a 1991, it is R12 so it is a bit trickier.
Is it better to convert to 134 or refill with R12?
Converting is a longer term solution but what is required and is it worth the effort as I can get all the R12 I need for no more than 100.
Thoughts?
Thoughts?
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Had my 91 converted to 134 and it works ok, I think it cooled better with R12.
Your 91 was pretty much designed for 134 with the larger air handling duct work. R12 does cool better, but not that much better. After 20+ years, most older cars have been successfully changed long ago to R134 with none of the doom and gloom stories of years ago. Its a very simple process, and you can buy the conversion kits at just about any auto parts store (even Walmart). And 134 must have saved the planet, you don't hear any more holes in the ozone stories (although there is those pesky R12 patent expiration stories).
I ask as my 82 required a few pieces for the swap.
Thanks!
134 has smaller molecules, so it tends to leak out more than R12. But time has shown its not a big problem. Anyway, your system is 25 years old so it probably seeps out anyway. The other concern was the compressor oil compatibility, but the new kits have taken care of that issue eliminating the need to flush the system as was once thought. Again, most pre 95 cars were converted successfully years ago, so much so its very rare to find one that hasn't been changed over, mainly collector cars that are rarely driven. A lot of times they didn't leave the 134 connector adapters on, or used a "drop in cocktail" from swap meets, so its hard saying exactly what is in your system now. There is a good chance you have something other than R12 in there now. There is a lot of information on the internet, and its been discussed many times (not so often anymore) here on the forum.
Normally it involves injecting that conversion Pag oil and changing over the fittings. However from my experience its just never works as good as R-12. New systems with 134 work pretty well.
Talk with Marc Haibeck about this. Back in the 90s GM put out a service bulletin that said you could convert to 134 without changing any of the seals. Just make sure the system is completely evacuated of the old R12. I had Marc change my '93 to 134 and never had a problem through all my years of ownership. I believe my '95 came from the factory with 134 but not certain. --Bob
I've had 90- 94 and 94 up C4s including ZR-1s, and haven't noticed any real difference in cooling. The ac systems are exactly the same except for the refrigerant (with the possible exception of minor hose and seal material and controller changes). Some people don't want the conversion adapters and stickers on an otherwise original car. Some people don't want the hassle of locating R12. What ever works for you .
I still have a decent supply of R12 so I have never converted my 90 over, but finding R12 at a reasonable price is not easy anymore.
I wouldn't convert if the system was still functioning. But now that you have to open it up anyway it's a perfect time to replace ALL "O" rings and hoses (if needed) and change it over to 134.
Rich
Rich
I found the fittings at Auto Zone for 12 bucks. I'll give this a shot this weekend.
I'll keep you posted!
I found more drag on the motor with R134a. I have since cleaned out the system and switched back to R12,
I do know that the Condenser was changed when GM went to R134a.. R12 was Tube & Fin, 134 is Parallel flow.. I swapped to a parallel flow with R12 and it seems to work well
