Bought a 90 ZR-1 - a few questions
Your car looks fantastic, D. Wish mine was white.
I've sent an e-mail to Movit for a quote.
Does the bracket for the second caliper go between the hub and bearing holder?
Larger diameter disc?
Dominic,
Is that a bolt on kit, or custom? Did you have to fabricate something to enable use of the ABS-sensor? Looks almost stock. Very nice!
Dominic,
Dominic,
Dominic,
It is a bolt on available from Street Stuff. In fact, there's a group buy going on the Registry for it. Not cheap but...
Don't know if it would work w 17s. The rear Z06 brakes are 13" rotors
The ABS sensor is not involved in this upgrade except that the eBrake cable is repositioned slightly to clear the sensor connector.
Hafsmo,
D.
Dominic,
Dominic,
See attached picture of the brakes.
Larger disc front and rear.
Rear Setup:
