C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
PCV Valve CV913C Help to Source
Old 01-31-2017, 10:03 AM
TealZR1
TealZR1's Avatar
Default PCV Valve CV913C Help to Source
Hello All-
Where can I find the CV913C valve that's spec'd in the manual? Checked AC Delco, Jerry's Gaskets and the interweb with no luck.
Thanks in advance!
Old 01-31-2017, 10:34 AM
FASTAZU
FASTAZU's Avatar
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I would give Jerry's a call he may have a suggestion on what to use. Here is a conversion list. Not GM but I hope this helps. I'm sure others will post up some information on this.
http://www.teamlucor.com/stores/gene...%20Catalog.pdf
http://www.rockauto.com/en/moreinfo....=1041387&jsn=9
http://www.whiteracingproducts.com/i...kqmvrljk08lgj2
Old 01-31-2017, 03:32 PM
AnthonyGS
Support Corvetteforum!
AnthonyGS's Avatar
I ordered the ones from rock auto.... all of them. I don't think it's the correct part. I will post what I know once I start my plenum maintenance. I may be cleaning the old one and reusing it.
Old 01-31-2017, 07:49 PM
74 LS4-454
74 LS4-454's Avatar
Finalist 2020 C4 of the Year - Unmodified
Even though I ordered different part number PCV valves from different vendors, they were all the same regardless. Ended up reusing one of the valves during the plenum pull, it was fine...
To PCV Valve CV913C Help to Source
Quick Reply: PCV Valve CV913C Help to Source
