Fuel pump/ gas tank removal
Location: No more yankee my wankee, the Donger is tired!
1 Post
Thought I would post some pics of a horrible project. Locobob has been having issues passing emissions. He had the tank tested and sure enough it pegged HCO meter. Upon removal you could see the rust in one of the seams. Crappy GM design.
http://www.pnwzr1.net/Robert/Gas_Tank/IMG_2348.JPG
http://www.pnwzr1.net/Robert/Gas_Tank/IMG_2347.JPG
http://www.pnwzr1.net/Robert/Gas_Tank/IMG_2346.JPG
http://www.pnwzr1.net/Robert/Gas_Tank/IMG_2345.JPG
http://www.pnwzr1.net/Robert/Gas_Tank/IMG_2344.JPG
http://www.pnwzr1.net/Robert/Gas_Tank/IMG_2343.JPG
http://www.pnwzr1.net/Robert/Gas_Tank/IMG_2342.JPG
http://www.pnwzr1.net/Robert/Gas_Tank/IMG_2340.JPG
So, what was the outcome?
BTW, thanks for the pix. I haven't seen that view before. A lot of stuff is laid bare there.
Pardon my ignorance, but why would rust cause an unusual reading. I would think maybe a clogged fuel Pump. filter, or trashed f.p. but?
The tank is rusted through at the rear seam. It's not bad enough to leak liquid fuel yet but it is allowing fumes to escape. The gas fumes are being picked up by the emissions testing equipment as hydrocarbons.
Originally Posted by Scoob
Get the build sheet while you're in there.
The bad news is the tank is not repairable, the good news is that all C4 fuel tanks are the same so it wasn't hard to find a replacement.
1 Post
Which pic shows that the best and is that seam visible without removing the tank or bumper?
Rob already answered the Emissisions question.
The job is easier than it looks. Book rate is 6 hours for removal and installation.
Originally Posted by Blown67427
Doesn't the gas tank have a rubber bladder inside ?
Kevin: I was going to try and get your tank but I found one at a local salvage yard for not much more than what it would cost to drive up to Washington. I'm having it pressure tested, should know tomorrow if its good or not.
