89 Corvette - 383, 6spd, supension mods, brake mods
89 Corvette - 383, 6spd, suspension mods, brake mods
1989 Corvette
154000 miles on body
White exterior, original paint in very good condition
Gray interior in decent shape
Black sport seats from 1993 in great shape
Climate control, all working fine including A/C
Dual power seats
Glass top
Was automatic, swapped in 6 speed tranny
Swapped Dana 36 for Dana 44 with 3.45 gear
Camaro single mass flywheel
Hurst billet plus shifter
383 stroker with 10.8 to 1 compression, less than 1k miles on it
40k mile 1991 L-98 block, machined for splayed main caps
Eagle 4340 3.75” stroke crank
Clevite 77H series racing bearings
Manley 4340 6.0” H-beam rods
Forged SRP dished pistons with Teflon coating
SpeedPro file fit rings
Cloyes double roller timing chain
Melling high volume oil pump
OEM oil pan
Lingenfelter 72219 camshaft
New OEM roller lifters
AFR 190cc heads with 7/16” rocker studs, angle milled
Crower Hi-Tech stainless steel roller rocker arms, 1.6 ratio
Aluminum valve covers
Edelbrock lower intake, ported
LPE Superram upper intake, ported runners
Edelbrock 58mm throttle body
Fluidamper balancer
Rotating assembly was internally balanced
Edelbrock high volume water pump
Aluminum radiator
Hooker 2149 coated long tube headers
Custom exhaust with 3.5” high flow cat and Dynomax mufflers
Computer swap to speed density computer (730 ECM)
Ed Wright computer chip
Koni adjustable shocks
Coil over conversion front and rear
30mm front sway bar
26mm rear sway bar
Tubular rear strut rods with rod ends
Polished front suspension
Poly bushings in the front suspension
C5/z06 front brakes
Stainless steel brake lines front and rear
17x9.5 sawblade wheels
Kumho Victoracer tires currently mounted up
Full Autometer gauges, just installed
Speedo, Tach, Oil pressure, Water temp, Oil temp, Voltage, Fuel level
The title is clean. This car is a great autocross or track toy that you can ride on the street with in comfort. It has all emissions equipment in place, although the EGR system has been disabled with the Ed Wright chip. I never used the car as a daily driver, so I have hardly put any miles on it myself. The only thing I have done with it is attend about 5 local autocrosses which are only a mile from where I keep the car. This has been a Fast Time of the Day car almost every time. The car is clean and tight, it doesn't have as much chassis flex as most I've ridden in.
There are a couple things that still need attention, but I am planning to take care of these asap. The new speedo isn't hooked up because I didn't really need it and I still lack a plug to match the sensor on the tranny. The same goes for the reverse light switch. There is also a spot on the right rocker panel that needs some touch up work. I will be taking care of all these very soon, although if someone wants it now I can offer the option to let the buyer take care of these things in the interest of saving a little off the purchase price.
Reason for selling is that I need money for the next project. I will be getting pics of everything I can today and tomorrow, and I'll post them up as soon as I have them ready. Car is located in Verona, Va.
Asking $13000
Will consider trades, partial or full. Things I will definitely consider:
Dually pickup
3rd gen RX7, complete or roller
LS1 Camaro
[Modified by Gary K, 8:29 PM 7/26/2003]
Dual power seats
Glass top
OEM oil pan
Fluidamper balancer
Aluminum radiator
30mm front sway bar
26mm rear sway bar
C5/z06 front brakes
Asking $13000
Dually pickup
LS1 Camaro
Re: 89 Corvette - 383, 6spd, suspension mods, brake mods (Gary K)
Pictures at http://www.krichbaum.net/forsale/89vette/ .
I ran out of daylight, so overall pics of the exterior are done indoors and aren't very good. I'll try to get some more tomorrow.
Also, I can offer options on the wheels and tires. I have the sawblades already listed, but could possibly swap out for Camaro SS wheels or AFS ZR1 replicas in 9.5" and 11" widths. Its completely negotiable.
[Modified by Gary K, 9:22 PM 7/26/2003]
Sounds like a serious car. I wish my car was that modded when it was purchased for me :D Good luck with the sale I am sure an enthusiast/racer will take it.
Re: 89 Corvette - 383, 6spd, suspension mods, brake mods (Vette9d1)
Thanks Vette9D1!
I have some better exterior pics posted now. They can be found at the link I posted above. Here is one of 'em:
BTW, if anybody wants high res versions of any of the pics, just let me know. I'm running these through a photoshop automated function, so they aren't looking as good as they could.
Price is negotiable! If this car doesn't sell, I'll probably start parting it out soon....I need money for my next project car.
Looks like a fast car. Not exactly what I was looking for but you did say trade, which is one of my favorite words. So... http://forums.corvetteforum.com/zerothread?id=601888
Hope you get to start your new project soon...Jeff
Re: 89 Corvette - 383, 6spd, suspension mods, brake mods (inverted99)
Jeff, looks like a nice car. I already have one of those sitting in the shop that I'm working on....well its Firebird rather than a Camaro, but very similar in preparation. Anyway, I think I'll pass on that trade, but thanks anyway.
Gary
Gary
Ok, reverse switch is hooked up and working along with the speedometer. Lots of interest but apparently nobody serious yet....maybe I'll ebay it next.
No harm in asking :D Someone will end up with a fast car, good luck in the sale. Thanks...Jeff
What about an extra clean LT1 Firebird for a trade- It's a 93/ 6 speed, very stock, with an extra set of wheels and Victoracers.
Re: 89 Corvette - 383, 6spd, suspension mods, brake mods (t.renz791)
Not exactly what I was looking for, but its a possibility. Send me some pics and what $$$ you think you'd want to give in addition to the car.
gary@krichbaum.net
gary@krichbaum.net
I'll borrow my friends cam and get some up to date pics to you this weekend.
I will also by at Carlisle next weekend if you are headed to the show.
Take care,
Tim :seeya
Take care,
Tim :seeya
Re: 89 Corvette - 383, 6spd, suspension mods, brake mods (Sharky Guam)
I'm not a drag racer, so I never have run it at the strip. I'd like to take it to the local strip to see what it can do, but its only a 1/8 mile track.
