02 z06 57000 miles built motor!!!!!
im saling my car im located in MS biloxi PM me if you interested thank you
Built 347 LS1 block
LG motor sport long tube header with X pipe
Callies rods
12:1 diamond piston 2 degree valve relief
450 precision injector
New crank
New fly wheel
Fast 90 intake/throttle body
Trick flow 215, 58cc heads ported
crower retainer
crower spring
ferrea valve
Comp. cam roller lifter
Comp. cam cr-mo push rod
Comp. cam cam shaft custom ground 242/244 624/622 111
3 degree advance
Harland and sharp roller rocker arms
RPM stage 5 tranny (new just install 2 week ago) w/spec stage three clutch
Coursa indy cat back
Stock z06 rear end with 342 gears
Nitrous express progressive system with bottle warmer/purge system
B & M ripper shifter
06 z06 rims
motor has 7800 miles on it when the car was at 55k now the car is 57k mile, this car will run low 10 with the right tires i have a video of it running mid 10s spinning down the track
http://videos.streetfire.net/video/M...ngs_193935.htm
skip to 4:10 and you see the run
exhaust clip
http://www.youtube.com/user/skydc2#p/u/0/0opz3QrJo4M
asking price is 28k OBO clear title
here some pic
http://forums.corvetteforum.com/newthread.php?do=newthread&f=52
Built 347 LS1 block
Callies rods
New crank
New fly wheel
crower retainer
crower spring
ferrea valve
3 degree advance
06 z06 rims
exhaust clip
here some pic
I am ineterested in your car but have some questions below...
Dyno # ?
What shot nitrous?
What is I wanted to add a super charger or is this motor built for nitrous only?
What suspension upgrades have you done?
Dyno # ?
What shot nitrous?
i dony have the dyno sheet but it made 545 rwhp on the 90 shot this car have a 12:1 compression so you have to lower that if you want to put a S/C and i have stock suspension
Would you maybe be willing to trade for a torch red 1999 fixed roof coupe corvette in perfect condition..very clean with a few bolt ons plus a 1991 GMC Sonoma? I work in gulfport,ms mon-fri. If youre interested let me know or give me a call at 601-934-4394.
