AZ, FS Low Mileage 2002 C5Z
SOLD! AZ, FS Low Mileage 2002 C5Z
SOLD!
2002 C5 Z06 – Modified
27,xxx
Black on Black
VIN:
Clean Carfax and Title
SOLD
530whp/475wtq on 91 octane
Location 85383, Arizona
p *deleted* (prefer texts but calls are OK, leave message)
e *deleted*
Two keys with remotes and all dealer books in leather-bound holder
Exterior 9/10 Some rock pitting on the rocker panels, rear brake duct openings. There is also a small nick on the DS door "bump" trim. Two wheels have some curb rash. Very minor and can be seen in the linked video. There is also a quarter size exhaust burn above the drivers side exhaust tip. The car has always been garaged and in most cases stored under the car cover as well.
Interior is a 10/10 Very clean. Has heads up display and the stock stereo. Ice-cold AC!
The car shows amazingly well and can easily go to either side of the spectrum (waxer or street machine) or both. Your choice!
Tons of power and torque on demand and drives through town like it’s a stock Z06. I receive compliments everywhere I have taken this car. This Z06 is the total package of looks, sound, comfort and performance.
The mods below were installed at 14,000, 19,000 and 23,000 miles. I have receipts to document all mods and installation prior to my ownership and all receipts of parts during my ownership. There is over $30,000 in receipts from the last 11,000 miles of this cars life.
Shipping is not an issue, I can get you a quote and set you up with the transporter I use.
EXTERIOR:
HID 6000K Bulb kit with slim ballast design
Tint 15% rear, 35% sides
Tow Strap (mounted behind front license plate cover)
INTERIOR:
Hurst Short Shifter with Delrin 3” ****
IPod 30-pin Dock Connector
Lloyd's Black Ultimats “Corvette Racing”
“Z06” Partition Divider
Autometer Cobalt Gauges w Pillar Pod (Fuel Pressure, Boost/Vacuum)
ENGINE:
Procharger P1SC1 w/ Twin 4.5” Intercoolers (full seal refurb 4/2/2014)
Remote SC Drain Line
FAST 92mm Intake (painted black)
LS7 Throttle Body
Custom Ground Blower Cam 222/226 (Mild)
Hardened Pushrods
Titanium Springs
Double Roller Timing Chain w/ Hardened bolts
60lb Injectors
Kenne Bell Boost-a-Pump
NX Inline Fuel Adaptor for Fuel Pressure Sensor
MSD Plug Wires
NGK Spark Plugs
Optima Red Top Battery
Dyno Tuned by Force Fed Performance Sacramento, CA
EXHAUST:
Kooks Long Tube Headers
Kooks X-pipe w/ High Flow Cats
SLP Powerflow Quad Tip Exhaust
TRANSMISSION:
RPM Level V 6 speed transmission
RPS billet twin with steel flywheel
Remote Clutch Bleed Line
SUSPENSION/BRAKES:
LG G2 Coilovers
VB&P Poly Control Arm Bushings
OEM Speedline Wheels
Nitto NT05 275/40/17 and 295/35/18
Wilwood SL6R Front Brake Kit w/ Floating 13.06” Slotted Rotors
Motul 600 Brake Fluid
Stainless Steel Brake Lines F/R
Alignment Specs;
Front Camber 1.35, Caster 6.5, Toe 0
Rear Camber 0.94, Toe 1/16” (1/32 total)
ALSO INCLUDED:
Black Car cover by COVERKING w/ Corvette C5 Logo
2002 3 Volume GM Shop/Service Manuals (Brand New)
Ebay Hockey Puck Jack Pads
2 seat belt extensions (1 BNIB)
Stock Fuel Rail/Valve Vanity Covers
Set of Wilwood Street pads
Set of Hawk Track pads
Walk-around/Startup Video
27,xxx
Black on Black
VIN:
SOLD
e *deleted*
EXTERIOR:
INTERIOR:
ENGINE:
LS7 Throttle Body
Hardened Pushrods
Titanium Springs
60lb Injectors
MSD Plug Wires
NGK Spark Plugs
EXHAUST:
TRANSMISSION:
SUSPENSION/BRAKES:
LG G2 Coilovers
Alignment Specs;
ALSO INCLUDED:
Final price drop. You'll be hard pressed to get more muscle and lower mileage for $26k anywhere!
$26k takes the car and extras!
Fresh oil and filter change performed yesterday. I also just put in a brand new hvac blower motor and blower motor resistor at $240.
