1999 frc lsx427 th400 novi 2200r 800 whp on low boost
Let me start by sayin no tire kickers please.. U send a deposit for me to hold u dont get it back.. Study what is for sale here then price it out
Price is 29k firm
Im located in albany ny
Pics text 5188587501
Motor... BRAND NEW
427 lsx block
Forged crank rods n coated pistons
Blower “BIG” Cam 239/254 .657/.630 115+4
Ls7 lifters
Ls7 manifold
90mm ported TB
Pfadt engine mounts
COMP Cams Hi-Tech pushrods 3/8 in. diameter Tapered to 5/16 in.
Ls7 stock rockers with comp trunion upgrade
meziere EWP
Trick flow 260x 6 bolt heads
Drivetrain. BRAND NEW
RSD line-loc
Rossler TH400 terminator 3 trans w/ tbrake, 1.97 billet gear set ..etc…
PTC 9.5 billet Bolt Together Torque Converter
Fully built rear W/ 500m short & long shafts w/ upgraded clutches etc...
B&M shifter
Quicktime flywheel Flex plate
RPM Extreme duty converter drive plate
DSS propshaft w/poly couplers & Modded TQ tube
DSS 1000HP Level 5 Rear Axle/Hub kit
DTE brace
New cradle and a-arms w/Poly bushings
Ecs safety hoops
Custom scorch tranny cooler system with 900cfm fan
Pfadt C5 Transmission Brace
Exhaust
ARH 2" Headers coated with corsa extreme exhaust
Suspension
Pfadt complete drag race package
Pfadt FeatherLight Generation Drag Racing Coilovers- Single Adjustable - http://www.pfadtracing.com/catalog/p...roducts_id/260
Pfadt C5 Rear Sway Drag Bar – ( I will not be running a front sway bar as I will be running slicks and skinnies) http://www.pfadtracing.com/catalog/p...roducts_id/256
Lg motorsports spindles
Welds 17x5 fronts
15x10 rear single beadlock
Fuel
Custom Scorch fuel system (good for 1500hp on E85)
Intank 400lph Walbro fuel pump
External Magnafuel 4303 fuel pump
Magnafuel MP-9950-B FPR
Magnafuel pre and post filter
Nasty Billet fuel rails
FIC 2200cc injectors
Check valve
Dual relay #10 line(x2)
-10an feed, -8an return
All the fittings and e85 compatible lines are black!
POWA!!!!
ECS Novi 2200R
ECS huge intercooler
Custom 10 rib direct drive
Upgraded HD ECS tensioner
Flip drive system
Procharger Big Red BPV
Dewitts big blower Radiator and spal fan setup
Scorch Custom Dual Evac system, -12an lines
Electronics
Stock ecu
Redline motorsports tune
2.0 bar
Custom switch panel
Led shift light
AFX wideband with NGK sensor
Prosport Halo Gauges (trans temp, fuel, boost)
All fuel lines and intercooler piping including HU housing and all brackets will be powder coated black
Body / Interior
Flat white blue pearl
Carbon vinyl roof
Carbon vinyl exhaust fascia
Smoked all lights
10" type r alpine. Sub in trunk with a Rockford prime 500 watt amp
Price is 29k firm
Motor... BRAND NEW
427 lsx block
Ls7 lifters
Ls7 manifold
90mm ported TB
Pfadt engine mounts
meziere EWP
RSD line-loc
B&M shifter
DTE brace
Ecs safety hoops
Exhaust
Suspension
Welds 17x5 fronts
Fuel
Check valve
POWA!!!!
ECS Novi 2200R
Flip drive system
Electronics
Stock ecu
2.0 bar
Custom switch panel
Led shift light
Body / Interior
Carbon vinyl roof
Smoked all lights
White vert
What is the reason for sale?? any et's?
Any roll bar? Please send more pics. To vette600hp@yahoo.com ]
L82 c3
I sent a PM but it got kicked back. I have a c3 that is listed here for sale/trade. PM me if interested. I have cash to ad on my end.
https://www.corvetteforum.com/forums/c3s-for-sale-wanted/3822472-75-l82-4-speed-for-sale-or-trade.html
