FS 2003 C5 Auto w/bolt ons
Selling my 2003 Chevy Corvette. 50th Anniversary Year!
I love this car and hate to let it go, my mom passed away and its time to make some changes. Looking for $13,000 obo. I still owe a little bit to the bank to get the title back i would pay them off and have them send the title to you.
Mileage as of today (10/17/2016) after work - 110399
The car runs and drives great, I've had it to Nashville 3 times in the past 2 years and drive it daily from Palatine to Rolling Meadows for work.
All the motor upgrades were done last summer and i added the the new rear-end this past summer.
The car has been painted with Halo EFX a Flat white this past summer. It can be pealed if you wish or leave it on to protect the car. The original color is gray. It has a 10" type R in a custom enclosure aswell as a JL audio amp, ,and a Kenwood touchscreen in-dash that has been custom molded into the dash.
Build list from Speed Inc.
SI1 Comp Cams LS1 220/220 .581/.581 112+4 3720R/3720R HR12+4
BTR-SK001 BTR .660 lift extreme dual spring kit with Chrome moly retainers
IZM9408051 Speed Inc 5/16" diameter, 7.400" Long Chrome Moly pushrods
CAMINSTLSET Camshaft installation gaskets
-GM Front cover gasket
-GM Water pump gaskets (2) 12630223
-GM Balancer bolt LS show contact info
-GM crank seal 12585673
-GM oil pump O ring 12557752
CD01-07-07 Circle D 278mm HP 4L60 LS Torque Converter *C5* *3000-3200 stall*
BM70264 B&M 24000 GVW Trans Cooler
NGKTR55 NGK Copper Spark plugs set of 8
MOR73660 Moroso LSX Ultra40 8.65mm Wire Set, 8" Car Coils 1 58.00 58.00T
DENSO234-4012 Denso C5 LS1/6 Oxygen sensor 1997-2003 (also fits LT1 Fbody)
Synthetic oil and filter change, coolant, for cam/heads installation
A/C RECHARGE A/C RECHARGE
Labor Installation- Speed Inc. Cam Package,
Front Cover Ga... Front Cover Gasket Fluids Trans Transmission R/R
Labor Installation- Torque converter and Trans cooler kit
Dyno tune 98-Current LSX, Including Road Tuning
MOTOR SPECS- K&N Typhoon CAI only, stock heads/intake manifold
GEARS- 3.42 upgrade
INJECTORS- stock
T-STAT- stock
CAM- SI1 220/220 .581/.581 112+4 3720R/3720R HR12+4
REV LIMITER
EXHAUST/CUTOUT- Texas Speed Long tube headers, no cats, Z06 Ti axleback exhaust
MAF- Stock
TUNING- Shift point adjustments for 3000-3200 Stall
FUEL-93 octane
Needs a little tlc, the abs and traction control lights are on, and there is a small vacuum leak the tuns on the check engine light from time to time.
GEARS- 3.42 upgrade
INJECTORS- stock
T-STAT- stock
REV LIMITER
MAF- Stock
FUEL-93 octane
