1999 Built, Procharged Corvette
6.0 liter engine built by DynoSpeed Racing, Memphis Tn paired with an intercooled Procharger setup. 503 rwhp, and only a few thousand miles on new engine. Previous owner spent 13 grand on the build. Needs meth, or the radiator angled and dropped for better air intake to achieve higher hp but the engine can handle much more. 6 speed trans, recently replaced rearend internals with ZO6 components also at DynoSpeed. only 67K miles on body. Text 901-832-5511 for more info and pics. Located in Hernando MS, just south of Memphis TN. 16,800
CorvetteBrent (12-31-2018)
Moderator
Looks awesome.
sighwest (11-13-2016)
Dang good deal here, folks. Super fresh forged iron 370 shortblock, 317 heads, PAC valve springs, Comp push rods, LS7 clutch kit, Melling oil pump, Dynospeed custom camshaft, Procharged, twin intercooled, long tube headers, Borla stainless exhaust, new visors, two sets of rear wheels-tires, new ZO6 rear end!!! fresh tint, low miles on the body at 67k. Engine built at around 62500 miles, so only 5-6000 miles on engine.
Headed to shop to investigate abs-traction control lights coming on Tuesday. If it's the sensors, will be replaced and there will be no issue with this car. Will let ya'll know.
Back from shop. Sensors issue fixed as the front left wasn't in correctly. New oil sending unit as the other was reading high. Back up to 16,300.
Admin please delete. Decided to keep it.
I had to add a can of Freon to the AC system last summer once. Small leak somewhere but held pressure and cold air the rest of the warm season. Cruise works fine.
Received 19,305 Likes
'20-'21-'22-'23-'24
Car sold, thread closed.
