2001 C5 Z06 Fully Built 765WHP 700WTRQ, CCWs, 60k miles
Well if you have ever wanted a turn key professionally built C5 Z06 here you go. I have an opportunity to jump on an investment so it's time to list this beast for sale. Car is in excellent condition and no corners were cut with this build. Car will come with CCW classics with pilot sports on the front and brand new Toyo Proxes TQ drag radials on the rear which are brand new. Also included are factory front wheels with brand new tires and Weld RTS 17 inch rears with ET Street R radials. Car was built by Kentucky Speed.
Mileage is 60,000
Text or call at 304-641-0070
Price : $31,000. Negotiable without CCWs
Modifications:
Engine.
383c.i. Stroker LS6
Callies Crank
Callies H-Beam Rods
Weisco Forged -32cc dished Pistons
241 Heads - Ported, Polished, 5 angle mill
Stage 4 A&A Blower Cam (Chops nice and hard)
ARP Headstuds, LS9 Head gaskets
LS6 Intake /Throttle Body/3-Bard MAP sensor
Innovative West 8" 8-Rib crank pulley
Power Adder:
A&A Procharger F1-A 8-Rib with a 4.25" Pulley (18psi)
Flip Drive Setup (8-Rib Supercharger, 6-Rib accessory)
4" Air Filter Intake Tube
A&A Intercooler and Tial 50mm Big Race Bypass Valve
Fuel:
Alky-Control Twin Nozzle Methanol System
Racetronics in-tank Fuel Pump(340) and harness
Secondary external fuel pump(255) on a Hobb switch
80lb Siemens injectors
LS6 Fuel Rails
Cooling:
Dewitts 2" Cut-Down Radiator
Dewitts/SPALDual Fan Setup
180 Degree Thermostat
Exhaust:
Kooks Longtube Headers
Kooks Catless Testpipe
Corsa Indy Car Exhaust
Drivetrain:
RPM Stage 3 Differential
C6 Z06 Short Shaft and Gear
C6 Z06 HD limited split clutch pack/springs
C6 Z06 Pinion Support
DTE Hardened Output Shaft
Micropolished 30-Spline, 3.42 Motive Gearset
Built T-56 (RPM Stage IV Equivalent)
Steel Shift Fork
Bronze Shift Pads
Carbon Synchronizes (1-2, 2-3)
Billet Blocker Rings (1-2, 2-3, 3-4)
Tremec 30-spline C6 Z06 Mainshaft
New Bearings/Seals Amsoil etc...
B&M Precision Shifter
Six Shooter Polyurethane Drive-line/torque tube couplers
Hinson Supercar polyurethane differential/ transmission mounts
C6 Z06 Factory Shocks
1/4" Aluminum Tunnel Plate
Miscellaneous:
Autometer Cobalt Fuel Pressure Gauge
Autometer Cobalt Boost Gauge
RK Sport High rise cowl Hood
Lowered on stock Bolts
Drilled/Slotted Black Zinc Rotors
Hawk Ceramic Pads
Radio-flyer 4500k Hella Pop-up Light Cannons with 4k HI Harness
Halo LED Taillights
LED Switchback Turn-signals
Lloyd floor mats
Lloyd Decklidtray/mat
Lloyd Trunk mat
Lloyd Cabin/Trunk Partition
Column Lock bypass
Mileage is 60,000
Modifications:
Engine.
383c.i. Stroker LS6
Callies Crank
Callies H-Beam Rods
Power Adder:
Fuel:
LS6 Fuel Rails
Cooling:
Exhaust:
Drivetrain:
Steel Shift Fork
Bronze Shift Pads
Miscellaneous:
Hawk Ceramic Pads
Halo LED Taillights
Lloyd floor mats
Lloyd Trunk mat
Column Lock bypass
IMXCITD (02-13-2017)
Spence680 (02-13-2017)
Spence680 (02-14-2017)
