Nick ECS Alky Tank Pics
Mark...I believe ECS builds those tanks in house so one could be built to fit. I am planning on building one later this year if I can get my battery where I want it.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
Originally Posted by mdhmi
Looks good. Are those tanks a problem if you have your car mini-tub'd ?
Mark
Mark
No problem with mini tubbs Mark
plus like Randy said, we build them here so give me a size and we can build it.
NOT TO SET ON ANY TOES, EXSPECIALLY ECS.
i built my own custom 3 gallon meth tank , with -6an line coming off the bottom thru the fiberglass wall to the rear of the car, the tank sits right down in the back of the car in the center section. Line comes off the back of the tank goes thru the fiberglass wall to the outside (between the exhaust pipes) with a 1/4"x3" brass nipple, then it gets picked up my 6an braided line goes thru a magna fuel inline filter and runs to the pump. The tank get fitted with a magnafuel roll over vent with a breather vented to outside the car. Then i removed the windshield washer float swith and wired it into the tank. This whole set will be posted with pictures. I will offer this tank set up for resale. Tank is made from 080 aluminum all hand tig welded.
Originally Posted by AVB
If you can do this on SS I'd be interested.. FYI, in discussions w/ Julio, Methanol and Aluminum don't go good together.. 100% methanol will corrode aluminum.
ok so are most guys running 100%? what material does the lines and resivior need to be?
Originally Posted by NICK YOSKIN
jay is resivior aluminum?
well thats news to me, but yes i can make the holding take out off polished stainless steel also.
well, i guess we can figure that out, this week when i show you the finished piece, you will be impressed with the tank, it has a lot of cool fetures to it, it has a raised area were the fill cap is, the bottom has a lowered funnel type swedge were the feed line is taped. Price really isnt my consern, making sure the members are happy with there product is my focus.
and yes the tanks will be fabricated the same way, all hand tig welded, using 16 gauge polished stainless steel, and then buffed for apperence. fittings are all made from steel. with S.S braided 6 an lines, check valve, and inline filter.
how much??
Originally Posted by Skunkworks
Methanol is very corrosive especially at 100% strength. How long to chew up aluminum I don’t know, but it will eventually.
Mike
Mike
Mike is 100% correct.
the stainless steel 3 gallon holding tank, includes braded lines ,steel fittings, check valve, air vent and triangle engineering aircraft style fill cap. This take can sits in the middle of the rearsection in the trunk, lines penitrate thru the rear fiberglass wall with all the needed fittings and run up to the pump. $450.00 for kit complete.
Dang you hijacked the hell out of this thread
