LS6 cam or leave stock LS1 cam??
Old 12-21-2005, 02:02 PM
0FRCBobby
Former Vendor
FRCBobby's Avatar
Default LS6 cam or leave stock LS1 cam??
Guys I have access to an LS6 cam and valve springs CHEAP, should I get teh LS6 cam or leave the stock cam in place?
Keep in mind that the car will be apart anyway to pin the crank.
Old 12-21-2005, 02:04 PM
mdhmi
mdhmi's Avatar
Definitely do the cam.
Mark
Old 12-21-2005, 02:06 PM
0FRCBobby
Former Vendor
FRCBobby's Avatar
you think it would be worthwhile even if only changing to the LS6 cam?
Also, I assume the stock LS6 valve springs will be ok, correct?
Also, what length pushrods should I go with?
Old 12-25-2005, 02:33 AM
Mopar Jimmy
Mopar Jimmy's Avatar
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Mark
You will make MORE POWER with the LS6 cam which happen to be very supercharger friendly cams!! Since your in there anyways and can pick it up for cheap seems to make good sense from a dollar to horespower ratio!!!
Old 12-25-2005, 08:32 AM
Hardtop01
Hardtop01's Avatar
I would put at least 918 springs in it. If the heads haven't been milled, I would use stock length, hardened pushrods.
Bruce
Old 12-25-2005, 12:01 PM
0FRCBobby
Former Vendor
FRCBobby's Avatar
So you think the stock LS6 springs aren't enough?? I already have the cam and valve springs in hand.
Going to be using the Thunder Racing 7.4 pushrods.
Old 12-25-2005, 12:13 PM
0Rob@ChampionMotors
Former Vendor
Rob@ChampionMotors's Avatar
Made 577rwhp and 749 rwtq with 02 ls6 cam. Make sure it's a 02 and up.
Old 12-25-2005, 12:14 PM
Mopar Jimmy
St. Jude Donor '06
I have researched this issue add nauseum of whether the stock Z06 springs are fine with a Z06 cam on a stock cubed motor that is using a centrigual supercharger and won't be spun past 6500. Most tuners including ECS told me to leave my stock Z06 springs in place as they should be fine and so far so good. Now if your going to shift past 6500 or go with a cam more aggressive than a stock LS6 cam, then definitely upgrade the springs to at least the 918s but better yet a dual spring like the comp 921 or patriot dual golds!!
I also know of several guys running the stock springs with their superchargers in their Z06s (stock LS6 motors) without any issues!
Old 12-25-2005, 12:20 PM
0FRCBobby
Former Vendor
FRCBobby's Avatar
Don't think it will be spinning that high. What does the the LS6 cam normally rev to?
Old 12-25-2005, 12:25 PM
0Rob@ChampionMotors
Former Vendor
6500 max. But max power range 5500-5800rpm.
Old 12-26-2005, 09:51 PM
0FRCBobby
Former Vendor
FRCBobby's Avatar
Thanks. Car is now tore down and cam will be going in on Saturday. Then the supercharger install will begin.
Old 12-26-2005, 11:09 PM
mdhmi
mdhmi's Avatar
One tip is to use a Gates laser alignment tool when installing the blower. Without every stinking pulley aligned just perfectly you'll get slip at best and chuck / rip belts at worst.
Mark
Old 12-27-2005, 09:36 AM
0FRCBobby
Former Vendor
FRCBobby's Avatar
Thanks for the tip. I will ensure the alignment is right.
To LS6 cam or leave stock LS1 cam??
Quick Reply: LS6 cam or leave stock LS1 cam??
