Procharger Oil Change
What is the best abd easiest way to change the oil from my Procharger supercharger? Detailed instruction would be appreciated.
Premium Supporting Vendor
Thanks for the info. Now, how the heck do you get the top screw off? Is there a special tool? Yes, I know this is probably a dumb question, but I need help.
Mine comes off with a large flat tip screwdriver...
Yep, I take mine off the same way. You might have to really put a bit of force on it to break it loose, but make sure it's a nice wide screwdriver so you don't strip out the slot.
