sc larger crank pulley for more boost?
I have a procharger d1sc(8 rib setup) and forged bottom end, currently running 10 lbs boost on a 3.75" blower pulley. I am trying to run 14 lbs, but get belt slippage if I go with a smaller pulley.
I am considering going with a larger crank pulley to provide the additional boost without reducing the blower pulley size.
Has anyone had luck with this approach? Good idea. Any suppliers of pulley kits for this type of conversion you can recommend?
Thanks!
Thanks!
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
Thanks Mark,
Our overdrive balancer is 8" in dia, which is a 10% overdrive and SFI rated. We have them in stock ready to go, if your interested give us a call. 609-752-0321
I am running a 4.00" pulley on a 346" with a D1SC. making 14.5lbs @ 6400rpm 70*f ambeint. Are you running something with a lot more displacement?
10lbs boost with a 3.75" pulley seems very low. Is your pulley presently slipping? Boost leak?
Originally Posted by usd2sing
I WANT YOUR TORQUE CURVE!!!!!..
very soon....
very soon....
I think you mean torque line.
(because it's so flat)
Thanks!
Thanks!
I am running a 4.00" 8 rib pulley on a 346" with a D1SC. making 14.5lbs @ 6400rpm 70*f ambeint. Are you running something with a lot more displacement? Power here is 711@ 600 RW SAE, as measured at ECS. not the inflated STD #s as posted earlier on a non equivalent system. 10lbs boost with a 3.75" pulley seems very low. Is your pulley presently slipping? Boost leak?
Do you have an older ATI system with the restrictive input to the supercharger?
Originally Posted by M_T_0
before and after dyno with the maggie and the ECS overdrive pully.
no retune no additional hardware just changed the crank pully
More Than Zero
More Than Zero
Those are great gains... and Doug is right.. Torque LINE... that car is a blast on the street.
Hi: the point I am trying to make here is not if turning the supercharger faster will make more power. But why is the boost at the level that it is reported at with the pulley size that he has. Maybe the problem is more fundamental than just changing pulleys.
