Magnacharger IC Coolant Pump
I want to pack my IC tank with ice the next time I run at the track
so I was going to install a screen in the IC tank to prevent any pieces
ice from entering my coolant pump and making it fail. But before I did
this does anyone know if the inlet nozzle on the coolant pump already
has a screen ?
Thanks >>>>> INTHERED
has a screen ?
has a screen ?
has a screen ?
Thats just a rough idea, I`m going to have to try some prototypes to come up with a final design.
Rick
Get a spray bar and spray the intercooler and run some Alky injection with it. That should cool it down some.
I don't think I would put ice inside the coolant. If you want to use ice, then build a tank to put the coolant tank inside with dry ice around it.
has a screen ?
has a screen ?
More Than Zero
Originally Posted by M_T_0
with the stock IC tank on the maggie you will not need to worry about the ice getting to the pump, It will not be ice long enough to make it there.
More Than Zero
More Than Zero
I recently had ECS put on the meth-injection. That should be a considerable improvement over the "inter-heater" of the maggie.
My friend has the CTS-V with a maggie. His intercooler is easily twice the size of ours. We need to find a larger intercooler, a double-core or such. Perhaps a small radiator from a compact import would work.
-ace
