20lbs of boost & 400+ Cubes = BOOOM?
#81
Big Boost CURE
Water methanol will allow you to run high boost like that. It retards detonation by keeping everything clean and cool. 15 lbs of boost can be ran safely on a LS2. Devils, Snow, or build your own.
#82
Supporting Vendor
I don't agree with the water part. Would run Alky Control before any other for many reasons.
#86
I'm sure that one will be getting revived any day now.
I'll just have to wait to see how my new 427 works out. If it breaks 800rw, I'll be thrilled.
#87
837hp 742tq, d1 14lbs, e85, ls2 402 08z trany and diff, finally got it running right, only car that has scared me yet. Thanks joey at excessive auto in sioux falls
#95
ISIS SUCKS FAT CHOAD
#96
Received 1,762 Likes
I cracked an LS2 with a forged 402 internals setup at somewhere over 18lbs boost. Replacing with same but gonna keep it below 15lbs.
Looking at a warhawk for another car. You may want to consider the iron block if you want that much boost and don't want to spend the $$.
I ran over 19 psi of boost with a YSI on it with almost 1,k RWHP on a mustang dyno. I had no problems with my motor at all. It may be also with this much rwhp the person that build the motor didn't do that good of a job...
Then again may just been a part that gave out on him also. Would be better if Doug post what it done from the parts in the motor when he gets it apart.
#100
Platinum Supporting Vendor
Robert Miller didn't even notice this thread is 9 years old, lol
