What Sled28 does over the holidays!
1 Post
St. Jude Donor '08
He goes to work and puts my little piece together!
And Rodney said one of these showed up for me-notice the max rpm? Special thanks to my Mustang buddy's
1 Post
St. Jude Donor '08
Fresh LS6 block, Callies 6.125 rods, Wiseco Pistons -2.2 cc reliefs, FM bearings, Stock crank keyed for Innovaters West 8" 8rib crank pulley, custom cam, stock LS6 heads with duals valve springs. Where gonna push the little 347 pretty hard-then maybe step up to a good set of heads, then a 402 with a Victor Jr intake.
Scotty
1 Post
St. Jude Donor '08
Push the little 347 pretty hard, step up to better heads, then push a 402 with VJ intake, then push LSX with worked LS7 heads, then step up to Procharger F-2, then add 1000 shot of NO2, then add turbine engine from MISS Budweiser, then..... Man Arun, your posts keep getting better and more ambitious, Way to Go Bro
Scotty
Scotty
-the plenom on this will allow you to run your stock hood. I'm not sure how much if any this will offer on a 347-I'm sure it will hurt slow speed torque-but I'm sure on a larger cube motor it may work very well. The Victor's nice you can plumb in so many things
I'm a nut Scott-I know-but realy feel these Centir's can keep up with the TT's. I found this pick of a Victor Jr in the for sale section:
Scotty
If its the same one, that still has air entering the top of the intake as normal, it looks incredibly restrictive.
1 Post
St. Jude Donor '08
It does seem restrictive but in the case of a blower app-you would figure a plenum that size would be full of air pretty quick-this was intended for the nitrous crowd-if it works for them it's gotta have some merit for us?
Nitrous adds oxygen to the incoming air....so it wouldnt really matter as much if the intake was restrictive. You are adding its "air" via an alternative means.
With n/a or indeed FI, air still has to pass through all the pipework etc. With a nitrous system you nearly bypass all the plumbing.
When a LS6 intake is well tried and tested. No way would I put an intake like that on my engine.
With a great engine builder like Sled28 behind you, your going to do some serious azz-whopin' once it's all done!
Good luck Arun, Sante and I are rootin' for ya!
Hey guys looks like things are coming together just fine. I am coming down in a week or two and gonna strat putting pieces of my puzzle together. 2007 season is gonna be great....Did u pick up the car yet Bro? See ya's in a few weeks...
If you go with a Victor Jr intake, do not use that POS elbow. There are better ones out there. This one is much better and will work on a C5 without any modification:
It is from http://www.intakeelbows.com/
Keith
Keith
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
Centri's "keeping up with TT's... they have been neck and neck if you think about it. The TTi X 346 guys are running around 9.7-9.8's, same with our Paxton kits. Last years baddest street turbo car that I know of was Stealth's car which ran a 9.33, Asmokegars Paxton street car finished the year at 9.33.
I sure times will drop this year as they always have, and past the point of a street car it's hard to beat a turbo, but for our applications they are pretty even. Just pick your poison
